0 registered (), 220 Guests and 0 Spiders online.
#97138 - 22/05/01 11:17 AM Towing capacities
onemadfool Offline
Loc: Reading, PA
I did a search and did not come up with a post covering this question. I am just curious...why does the A/T have a higher towing capacity than the M/T? In my owners manual it says the a/t can tow 5000lbs, and the m/t is only 3500lbs. Why is that? Does it have to do with the way they are geared?
Any info is appreciated.
Onemadfool
DO YOU LIKE PANCAKES?
2001 XE V6 4x4 5SPD Aztec Red AOL IM - mtg junkie
communities.msn.com/OnemadfoolsXterraShrine
"If I wanted smoke blown up my ass, I'd be at home with a pack of cigarettes, and a short length of hose." --The Simpsons
#97139 - 22/05/01 11:36 AM Re: Towing capacities
wqbang Offline
Loc: Auburn, WA
Liability issues. Nissan underrates the MT's towing capacity so that it doesn't have to warranty smoked clutches owned by people who don't know how to tow.
In most cases *with proper technique*, a manual tranny can tow more than an auto.
:wq!
Senior Member - Southeast Xterra Club
Tread Lightly!
Tread Lightly!
#97140 - 22/05/01 03:18 PM Re: Towing capacities
GordP Offline
Loc: White Rock, B.C. Canada
In a round-about way, I guess you could say gearing is one factor.
The manual transmission has "hard" gears, with a fixed/known 1st gear. On the surface, comparing gear-ratios, it appears the auto tranny has poorer gearing...
But - the auto tranny has a torque convertor! Below the stall-speed, the fluid is in "shear", and the convertor performs a "torque-multiplying" function. American General and others specify a multiplier of 2x for this. So, rather than a first-gear of 2.5:1 (for example), the auto tranny's convertor makes this more like a 5:1 first gear. Significantly lower than the Xterra manual-tranny.
There are domestic truck manual transmissions with "granny" gears, featuring 5.6:1, 6:1 or even 7:1 first gears. It's rare that you can use these on the street, but towing or getting a heavy load moving is one great use for them.
In the case of the Xterra, I think it's simply the lower-effective-gearing offered by the automatic.
-GordP
2001 Solar Yellow XE (S/U/P)
31" ProComp M/T tires
tow hooks, storage shelf, Warn hubs
