#778 - 02/01/07 08:47 PM scan gauge Two!
Hello, You may want to take a look at (Club Xterra) forums and look up: Interior mods....to sign up to buy this Scan Gauge Two. Worth while getting!
#779 - 03/01/07 08:41 AM Re: scan gauge Two!
Little behind the times...I've had a ScanGuage II for almost 6 months laugh
#780 - 03/01/07 03:01 PM Re: scan gauge Two!
Hello, Can you get MPG while driving? How to you like it? and what is the best use for you? ........Aloha
#781 - 03/01/07 05:35 PM Re: scan gauge Two!
XPLORx4 Offline
Loc: San Jose, CA
I have two SGII's. One in my Pathfinder, and one in my Mazdaspeed6.
In the Pathy, I use it to display voltage (VLT), engine coolant temp (°FWT), instantaneous MPG (MPG), and either calculated engine load (LOD), manfold absolute pressure (MAP), or throttle position (TPS), depending on conditions. It's also useful for displaying accurate MPH if you have oversized tires.
In my Mazda, I use it to display MPG, MAP, ignition timing (IGN), and LOD. Since my Mazda is turbocharged, the MAP display can show boost pressure in absolute PSI (i.e. boost = MAP - 14.7psi)
The SGII calculates your average MPG during the current drive cycle, the previous day's MPG, today's MPG (if you have multiple short errands through the day), as well as overall MPG for the current tank of gas.
I find it very useful to track in real time the effects of driving at different speeds in my daily driver (Mazda). Yesterday, I drove 80mph on my freeway commute, and got 22.3mpg. Today, I drove 65mph on the same route and got 26.2mpg.
4x4 in uppercase is $X$!!!
