0 registered (), 133 Guests and 2 Spiders online.
#683023 - 29/01/17 06:16 PM '04 Cranks, wont start. Hoping I missed something simple...
adrenalinemedic Offline
Loc: Roseville, CA
Background: 2004 SE with 222,224 miles on it. It runs just fine, and was doing so on a drive down to SF on Friday. No issues with starting, low power, bogging down on hills, nothing. Sat morning I go to start it and it cranks strong but wont start.
Had it towed home, and have been troubleshooting all day.
I've ruled out:
Battery: tests as fine.
Battery connections: Cleaned and re tightened.
Fuses: Checked ALL fuses to be sure. Replaced fuel pump fuse because I could.
Fuel pump: You can hear it priming when the ignition is turned but not started.
Fuel sending unit: Checked for corrosion and melting on and around contacts. No issues.
Fuel filter: Just replaced it an hour ago.
Distro: Not loose. It's on its third distro, and this one went in 6 months ago and I checked timing two months ago. Contacts are clean and the rotor looks fine.
Timing belt. It's on it's third one (every 100k). I cranked it with the distro cap off and the rotor consistently turned.
Starter: It cranks just fine and the starter is about 2 years old.
Security system: Triggered and disarmed the alarm. Unlocked the car manually with key in drivers door.
It's not throwing any codes. It's not hesitant or slow to crank. The only thing I don't have is a spark tester, but if one of the plugs or wires was bad, it would catch and just run like crap.
Any suggestions?
Edited by adrenalinemedic (29/01/17 06:22 PM)
#683025 - 04/02/17 02:49 PM Re: '04 Cranks, wont start. Hoping I missed something simple... [Re: adrenalinemedic]
Glim Offline
Loc: Sc
Have you checked fuel pressure? Also see if you are getting fire could be a cam or crank sensor
It's not stuck I just like it there
