0 registered (), 133 Guests and 2 Spiders online.
#682552 - 25/06/14 07:44 PM leakage smoking on drivers side
Bolt Speedman Offline
Loc: Jackson, Wisconsin
03 3.3 6cyl non sc....fluids leaking under heat shield..not sure if there's a line under there somewhere. Smoke comes from under the heat shield and when I drive a little bit, whatever it is is spraying on the left suspension making squeak bad...let it sit a few days, starts and runs fine, til it gets warm and smoke again. Originaly thought valve cover gaskets because they do leak but they wouldn't spray under pressure. Any help before the dealership fucks everything up?
If your stupid today, it's a safe bet you'll be stupid tommorrow!
#682554 - 26/06/14 09:57 AM Re: leakage smoking on drivers side [Re: Bolt Speedman]
johnsx Offline
What color is the fluid? Any low fluids? Antifreeze, the cooling system is under pressure and will spray.
Original owner 2000 X
