0 registered (), 47 Guests and 0 Spiders online.
#682521 - 29/05/14 04:25 PM AC doesn't work
Wally's Kid Offline
The AC doesn't work on my 2000 SE. No power going to the compressor. Both fuses are good and the relay tested good. The relay doesn't "click" when the AC switch is turned on. The light on the AC switch turns on. Can anyone help? Thanks!
#682524 - 01/06/14 08:49 PM Re: AC doesn't work [Re: Wally's Kid]
Is your fan resistor blown?
#682529 - 04/06/14 04:49 PM Re: AC doesn't work [Re: TJ]
Wally's Kid Offline
I replaced the resistor a while back and the fan works on all speeds. I've found that there is no voltage going to the thermo amp so now I'm thinking that the power switch is bad--if thats the case the entire climate control would have to be replaced. Am I missing something?
