0 registered (), 188 Guests and 0 Spiders online.
#680729 - 22/11/13 09:37 PM 2002 xterra runs rough when idle
johnson616616 Offline
Timing belt, spark plugs, water pump, thermostat, cables were changed and when it idles, the RPM starts to go down and the engine shakes. there is a knocking noise from the super charger. then, the RPM start to go up again. this happens every 20 to 30 seconds. The computer gave code 330,. everything was checked again and no luck. could it be vacuum problem? Please help
#680731 - 22/11/13 09:38 PM Re: 2002 xterra runs rough when idle [Re: johnson616616]
