0 registered (), 145 Guests and 0 Spiders online.
#680393 - 12/08/13 08:27 PM Seized engine opinions?
RNTKnives Offline
A
Friend of mine has an '03 XE, 3.3l, 90K +/-, I believe it's an auto, 2wd. Drove to the store Sun. and shut it off. Came back out and only got a "click". Battery good, cables good, starter good, selenoid is clicking and all fuses 100%.
Towed to a "mechanic" who claims the engine is seized (locked up were his words) because he can't turn it by hand. I'm thinking he's trying to turn it by the flywheel. I haven't seen the truck since this issue started, but it's always been maintained. Has never overheated.
Is it possible to drop the timing belt at shutdown and stop in such a manner as to prevent the engine from turning?
Any thoughts?
ThanX...
Jeff!
Pre-crash post count - 396
#680394 - 13/08/13 05:48 PM Re: Seized engine opinions? [Re: RNTKnives]
Kind of hard to tell from here, but I have heard of it going w/o being noticed if it goes at shut down, etc. You can double check at the dizzy sometimes, etc...or just open it up and look.
#680398 - 13/08/13 08:42 PM Re: Seized engine opinions? [Re: TJ]
RNTKnives Offline
A
Turns out it may be the starter after all. Starter was bench checked and it spun, but apparently not enough nuts to turn the engine.
ThanX TJ...
Jeff!
