0 registered (), 165 Guests and 0 Spiders online.
#679745 - 12/02/13 07:14 PM 2005 Xterra - No power at the fuel pump
gorlosky Offline
Need help. I have a 2005 Xterra and it just would not start one morning.
1. Pulled the spark plug and it was dry with good spark.
2. Pulled off the fuel connector at the engine and no pressure.
3. Listened for the fuel pump to run, when key is truned to ON, but no sound.
4. Checked the 15 amp fuse and it is good.
5. Swapped the Fog relay with the ECM relay, but no luck.
7. Confirmed that the fuel gauge was reading accurately.
8. No Security light on the dash, so that is good.
9. Tried the other key, but no luck.
10. Dropped the tank and tested using the red and black wires and the pump runs just fine.
11. Tested continuity for the fuel pump wiring harness Black ground and it is good.
12. Tested the fuel pump wiring harness and no power to the Red wire, when key is turned on.
What am I missing ?
Is there anything that I can check on either leg of the 15 amp fuse ?
Does anyone have a wiring diagram showing from the battery to the pump and the components in between ?
#679746 - 13/02/13 06:05 AM Re: 2005 Xterra - No power at the fuel pump [Re: gorlosky]
There might be a relay to the pump that went bad.
There's a wiring diagram in the 2005 FSM
Edited by TJ (13/02/13 06:06 AM)
#679747 - 13/02/13 07:18 AM Re: 2005 Xterra - No power at the fuel pump [Re: TJ]
gorlosky Offline
Can you point me to the 2005 FSM on this forum or anywhere ?
I have an electronic version, but not sure if it is a Full Service Manual.
Edition: February 2005
Revision: February 2006
Publication No. SM5E-1N50U2
NISSAN XTERRA MODEL N50 SERIES
with these sections:
K ELECTRICAL
SC Starting & Charging System
LT Lighting System
DI Driver Information System
WW Wiper, Washer & Horn
BCS Body Control System
LAN LAN System
AV Audio Visual & Telephone System
ACS Auto Cruise Control System
PG Power Supply, Ground & Circuit Elements
In what section would I find the entire electrical path from Battery to Fuel Pump ?
Edited by gorlosky (13/02/13 07:19 AM)
#679750 - 13/02/13 07:32 AM Re: 2005 Xterra - No power at the fuel pump [Re: gorlosky]
gorlosky Offline
Additionally I guess I am looking for a Troubleshooting Guide or a Diagnostic Guide that has the Step by Step and the Meter readings like depicted in Section G1
HOW TO FOLLOW TEST GROUPS IN TROUBLE DIAGNOSES
#680252 - 04/07/13 11:31 PM Re: 2005 Xterra - No power at the fuel pump [Re: gorlosky]
camron Offline
I think most of the time your ignition and other electrical system will not start when you have a problem with your alarm system or door sensor.Because when door sensor are not properly work the ignition system and other components don't work.So just disable the alarm and than try that.
Be Secure, Be Safe
