0 registered (), 148 Guests and 2 Spiders online.
#678888 - 10/07/12 05:40 AM Aftermarket stereo install q's
jackertheberry Offline
Loc: SE Ohio
I just purchased this Pioneer unit for my '03 SE:http://www.pioneerelectronics.com/PUSA/Car/CD-Receivers/DEH-P7400HD
I also have this coming as well:http://www.metraonline.com/part/99-7417
Curious as to whether the stock wiring harness that connects to the old Rock Fos unit will mate up with the new unit? There's also plug-in points on the back of the new Pioneer unit for steering wheel stereo controls and for the antenna.
Will I need to purchase any other adapters for this particular install?
Thanks in advance for any help!
#679299 - 15/10/12 07:04 AM Re: Aftermarket stereo install q's [Re: jackertheberry]
DeliriouX Offline
Loc: ontario canada
the mounting kit you ordered is correct, axxessinterface.com will have what you need for steering wheel controls. i am not 100% sure on the power harness adaptor but it looks like a standard nissan adaptor for rockford or standard radio re and re. just be sure to hook up the amp turn on wire (blue wire with a white tracer stripe). if you like fm radio the pioneer is a great choise for its stronger than most tuners. i am a car audio installer but have not done any xterras since they were still new to the market. also some nissans used a double diversity antanna and you will need the adaptor for that too. hope this helps. new here and as far as i can tell i will be owning a 1st gen xterra within two weeks...fingers crossed
#679940 - 24/03/13 09:05 PM Re: Aftermarket stereo install q's [Re: DeliriouX]
xterra79 Offline
I wanted to install a new GPS Dash on my 2012 model, but not sure if it will void the warranty. Do you know if it does.
