WHY you want a lift is a key issue.
A Body Lift is cheap and easy...but really meant to make room for larger tires to retain uptravel/articulation, etc....
...so adding a 3" BL and leaving stock sized tires might look like a bit ...um ...wasted space in those wells.
If you're going off roading, a BL and larger tires WILL do a lot for you...as larger TIRES lift the entire rig, axles and all.
WHY do you want ~ 3" of lift?
