0 registered (), 148 Guests and 2 Spiders online.
#677935 - 13/02/12 12:17 PM 2001 4x2 Rotors
brian74d Offline
Loc: Palm Bay, FL
I am needing some help figuring out how to get the rotors off of my 2001 4x2 XE V6. I can't find it in my Haynes manual and something painfully easy must be escaping me, but please help out the newbie. Thanks in advance.
2002 Xterra SE (3.3 Auto 4x2)
If you're surrounded, it only simplifies your problem.
#677942 - 13/02/12 04:15 PM Re: 2001 4x2 Rotors [Re: brian74d]
Nissan_MasterTech Offline
Loc: Florida
you'll need to remove the brske caliper and torque member, the torque member is what holds the pads.
next remove the dust cover in the center of the hub.
next remove the 2 screws that secure the locking ring and remove it.
next use a punch to unscrew the threaded locking ring.
then pull off the rotor, be sure to catch the front wheel bearing, don't let it hit the ground, you'll need a new one if you do.
flip the rotor/hub assembly over, on the back side you'll se 6 bolts, remove them to seporate the hub from the rotor.
