I just did a 2" BL and a 2" SL, and went with 33x12.5's and I'm rubbing bad up front (only when turning, on the back side of the wheel well, the usual spot). I'm not sure what my next step is, but it's not really drivable the way it is. I'm pretty sure the basice melt mod isn't going to cut it. Any ideas???
1. What year X do you have?
2. What's the backspacing of your rims?
3. If you have a 2005+, you should need no more than a melt mod unless you got too little BS on your rims.
4. If you have a 2004- you need to remove the plastic ledge at the rear of the front wells that the lower mud flaps used to screw into...unless you have too little BS on your rims.
5. If you have too little BS on your rims (Adding spacers deos the same thing, etc...), then you need more room for the tire arc to swing through, and you need to get less BS, or, BFH back the metal parts.
6. You can also adjust the turn stops to reduce the hitting on turns.
