0 registered (), 378 Guests and 2 Spiders online.
#657525 - 13/06/06 11:12 PM squeaky suspension
My front end squeaks whenever I go over bumps. I got a 2001 4wd. do i need to replace something or a simple lube job...and if a lube job, any guidelines, tips. Thanks
#657526 - 13/06/06 11:41 PM Re: squeaky suspension
forget it, i browsed and i found the answer on another topic. thanks
#657527 - 15/06/06 06:46 AM Re: squeaky suspension
Where did you find this fix? I have a similar issue and your solution would be beneficial to me.
#657528 - 15/06/06 08:57 AM Re: squeaky suspension
Check here for your squeak solutoin.
Squeaky Squeaky
#657529 - 23/11/06 12:21 PM Re: squeaky suspension
For what it's worth I spent about 2 hours under my X lubing, driving, and then re-lubing various suspension parts with no luck. mad Checked out a few posts, tried a few things, and at least in my case it turned out to be the hood latch. Would have bet $$ that the noise was coming from either the coil assembly or A arms under the vehicle, particularly the driver side wheel well... oh well, live and learn - adjusted the stops out 1/4 turn and put some bearing grease on the 'hook' on the hood and no more problem. [drink]
