1 registered (Tom),
167
#607510 - 10/11/07 07:50 AM
Re: Airplane on a treadmill question
Anybody who has some extra time can try this.
Get a box/window fan and put some wheels on the bottom set it on a treadmill and turn it on high. It should move forward on the treadmill. Now crank the treadmill up to 10mph and observe what happens. The fan is still moving air but likely the fan will break when it goes flying off the treadmill into the wall.
#607511 - 10/11/07 07:54 AM
The answer is yes....basically for the reason I stated.
If you are running on a treadmill, and someone who is not on the treadmill pushes you from behind, will you move forward on the treadmill even though your running speed hasn't changed?
You = Airplane someone pushing you = engine thrust. No you wont move forward because the treadmill is supposed to speed up to compensate
#607513 - 10/11/07 08:13 AM
The hovercraft scenario is stupid it is different forces acting...Thats like saying if a plane is flying at 5,000 feet and somebody turns on a treadmill does the plane go backwards.....The ice skating one I haven't read and dont feel like searching for
#607515 - 10/11/07 10:50 AM
You guys do realize that it's been almost a year since the original thread was started.
#607516 - 10/11/07 11:01 AM
This helped my friends see... You have a AWD car on a AWD dino, no matter how fast those tires spin the car goes no where. You put a fucking JEt engine on the roof that produces thousands of pounds of thrust and start it up, your telling me that the car would not move? Too many beers drank one night on this one.
The plane will take off.
#607517 - 10/11/07 12:53 PM
Infx, the plane moves forward relative to the belt and relative to an outside observer.
The conveyor can only push on the bottom of the wheels, causing them to spin. No matter how fast the conveyor goes, it can only spin the wheels.
The plane moves forward by acting on the air, not on the tread.
BTW, if the aircraft goes nowhere, it has no speed. If it does stay in one position, it has NO SPEED and therefore the conveyor would have no speed. The plane accelerates to 10 KIAS (knots indicated airspeed), the conveyor moves in the other direction at 10 knots, the wheels rotate at a rate of 20 knots. The conveyor is powerless to halt or apply equal force to the aircraft because the thrust works to move the entire plane along, while the conveyor can only puch on the bottom of the wheels.
infx, did you read my examples with the skateboard or the aircraft doing a touch-and-go? If the aircraft doing a touch and go would stop on a dime (as your answer indicates) the navy would save billions on carrier suitability testing and you could land anything with wheels on a 200 mile ling conveyor/runway.
#607518 - 10/11/07 04:50 PM
Originally posted by BurgPath: After all this I'm left with wondering how a plane on a movable platform (conveyor/treadmill) can generate enough air over the wings to achieve lift.
But doesn't this whole thing ride on if the plane moves forward on this infinite treadmill? If it sits still because the belt keeps up with its thrust, it will never take off.
If the plane can over come the rolling resistance to move forward eventually it will.
That sound right? Originally posted by InfX708: You all fail to accept that there is relativity involved here. The speed of the treadmill relative to the plane is different to the speed of the treadmill relative to ground observer. I've said it before. In this example, the plane moves forward on the belt at a given speed. The belt moves backward at the same speed. By definition, the plane isn't going anyplace. If you apply more thrust, the plane moves forward faster than the belt is moving backward. In order to take off, the plane must move faster than the belt, otherwise its place in space doesn't change, only it's position on the belt.
Maybe this will clear things up for everyone. If you put a guy on the treadmill standing still and he shoots a radar gun at the airplane, he shows that it is departing his position at 300mph. The pilot shoots a radar gun down at the runway and shows the runway whizzing past at 300mph. Since by definition the treadmill belt is moving, the plane is stationary in space and thus has no air flowing over the wings and thus creating no lift. The engines are simply maintaining the aircraft's 300mph forward movement along the belt. If you shut off the engines, the airplane would drift backward until its wheels lost their inertia, then it too would begin to move backward at 300 mph. These two explain it all. Yes the engines will "move" the plane. Who cares about what is holding up the plane, wheels, on ice, hovering or whatever. The treadmill is going to prevent air resistance from passing over/under the wings, because the airplane is not moving against any air. No one has said where the air is coming from to provide the lift for the wings. The plane will move, yes. But not Fly.
#607519 - 10/11/07 05:08 PM
Loc: Knoxville, Tn
John can we set up a real world test next weekend? Still not buying the the plane will take off. Move forward? Ok. I'll buy that. Achive enough forward motion to generate enough lift? Nope.
#607520 - 10/11/07 07:12 PM
Originally posted by chumpmann: Originally posted by BurgPath: [b]After all this I'm left with wondering how a plane on a movable platform (conveyor/treadmill) can generate enough air over the wings to achieve lift.
The plane will move, yes. But not Fly.[/b]How the hell does a treadmill produce a vacuum???? The air that flows over the wings to create lift is already there...You're making this much harder than it has to be. If the plane can move, it will take off because the wheels are not providing any propulsion. If the treadmill is moving at all then the plane is moving and if the plane moves then it takes off.
#607521 - 10/11/07 07:30 PM
Tyler, I already gave up trying to prove that the plane will take off. It's a lost cause. ![laugh laugh](/forums/images/graemlins/default/laugh.gif)
#607522 - 10/11/07 08:58 PM
Originally posted by AHTOXA: Tyler, I already gave up trying to prove that the plane will take off. It's a lost cause. Don't give up, this thread is the most entertaining thing I've read in a while. ![laugh laugh](/forums/images/graemlins/default/laugh.gif)
#607523 - 10/11/07 09:14 PM
Originally posted by vitaly: Originally posted by AHTOXA: [b]Tyler, I already gave up trying to prove that the plane will take off. It's a lost cause. Don't give up, this thread is the most entertaining thing I've read in a while. [/b]Tony, I can't give up when I see conceptual leaps across the Grand Canyon...makes my brain hurt vitaly, check out the original thread...titled something along the lines of "Know that if you don't post in this thread today the world will end" or some such crap.
#607524 - 10/11/07 10:03 PM
Originally posted by BurgPath: John can we set up a real world test next weekend?
Nope.If it can move forward an inch, then it can move forward enough (given enough take-off distance) to take off. Plain and simple.
#607525 - 11/11/07 02:52 AM
Loc: Ft. Bragg, NC
Originally posted by MattyX: Infx, the plane moves forward relative to the belt and relative to an outside observer.
infx, did you read my examples with the skateboard or the aircraft doing a touch-and-go? If the aircraft doing a touch and go would stop on a dime (as your answer indicates) the navy would save billions on carrier suitability testing and you could land anything with wheels on a 200 mile ling conveyor/runway. The plane cannot move forward relative to both at the same speed. Not going to happen, unless the fixed observer is also moving forward in space, in which case he wouldn't be fixed. A touch and go has nothing to do with it, unless it's a Harrier dropping straight down and going back up, which is outside the scope of the question. In the question the plane is not moving forward in space. In order for it to match the rearward speed of the treadmill, it can't move forward or backward of it's present position in space. Basically, you are trying to tell me that the treadmill is spinning the airplanes wheels and thus it takes off. While there is some airflow from the treadmill, there is not enough to generate lift. In order for lift to occur, the plane has to move forward of its present location in space. Since is is only moving forward of its current position on the belt, it is static in space. The engine just keeps it moving forward on the belt at the current speed of the belt. Now, if you applied more thrust and moved it forward along the belt faster than the belt is moving backward along its track, then yes, the bird will fly, but then it has exceeded the parameters of the question. If you really think the conveyor will just spin the wheels, you're not being realistic. Sooner or later the force of the belt pushing backward will overcome the "at rest" inertia of the plane. It will need forward thrust to maintain a forward speed equal to the belt's reverse speed, i.e. maintain its place in space. I think this is a question dreamed up by philosophy majors as payback to engineers for making the following joke: Q: What's an engineer say? A: How Does it work? Q: What's a scientist say? A: Why does it work? Q: What's a liberal arts major say? A: Do you want fries with that?
300,000 miles, and counting
#607526 - 11/11/07 07:55 AM
Geez. It is utterly amazing how many of you dumbasses haven't taken high school Physics I. The plane takes off. Ancient History The correct answer has been well explained: Originally posted by Chris Ritchey: I admit I didn't read all 52 pages, just 15, so maybe it was mentioned in the remaining pages, but I just want to add a few things.
[b]Definitions- wind speed: speed of the air relative to the plane, 100mph wind speed means the wind is moving 100mph across the wings.
- Global Perspective: This is the perspective being observed from the outside world, an example would be some one not standing on the tread mill watching the plane try to take off
- Scenario perspective: Perspective from the plane, relative to the treadmill
- Relative speed: speed of the treadmill as observed from the Scenario perspective, aka the plane
- Absolute speed: speed of the treadmill as observed from the Global perspective.
Assumptions- conveyor belt only moves the ground below the plane, not the air around the plane, and moves in the opposite direction the plane is trying to move.
- weather is ideal and wind is calm (0MPH).
- group speed = air speed since the plane is on the ground.
- wheels are freewheeling, ie there is little if any rotational friction between the wheel and the object it is attached to.
- plane would be able to take off if the tread mill was kept stationary.
Facts- lift if determined by the wind speed over the wings.
- Thrust produced by the engines (prop or turbine) applies a force against the air.
- Thrust is dependent on wind speed, the higher the wind speed the lower the thrust, and vice versa.
- Force from the thrusters is what propels the plane and not the wheels.
- air is a fluid
ProofThe tread mill doesn't effect the speed of the wind:Lets just say for the sake of argument that the tread mill does move the air around the plane at the same rate as the treadmill. If the plane is trying to go down the run way and is stationary from the global perspective the the wind will increase in speed as it passes over the wings. This equivalent wind speed will cause enough lift for the plane to take off, this scenario is essentially the same as if it was going down a normal run way. So we know that the tread mill does not effect the planes air speed because if it did it would be able to lift off. If we look at a force diagram, the engines produces thrust forward by "throwing" air backwards and pushes against the air already present which produces a force pointing in the forward direction, this is because of newtons third law, equal and opposite reaction. So a force backwards produces a force forwards. The ONLY way for the plane to stand still from the global perspective is to have another force applied to the plane that would counter act this forward force, other wise the plane will move forward since F=ma (Force = mass X acceleration). Here are some possible options that could produce the required force to prevent: - Air resistance, which is determiend by surface area and wind speed
- Excessive friction between the plane and the ground, for example Wheel Brakes are applied, or wheels are not present wheels.
- Plane is chained to a solid anchor
As seen by the fact that a high enough wind speed would creates lift and allow the plane to take off we can rule out wind, as enough wind the keep the plane stationary would surely allow it to take off. Now if we make the assumption that the plane would be able to take off if the treadmill is kept still like a normal run way we can safely assume that plane has little resistance relative to the force generated by the thrusters. And that there is nothing nothing else binding the plane such as it being anchored. So we are safe to assume the airplane is not held by any external constraints. Plus we know the wheel brakes are not applied because otherwise the plane would not be able to move anyways and the question is a trick question So without any kind of constraints it is impossible for a plane to not move from a global perspective when it is at full throttle because there is no resistance to the forward force and because thrust and wind speed are inversely proportional therefor there will be a force acting on the plane moving it forward increasing the wind speed over the wing allowing for take off. ... In summary The planes method of propulsion acts on the global perspective and not on the relative perspective allowing it to move in the global perspective as well, even if the wind was acted form a relative perspective it would be able to take off since it would have a high enough wind speed. so yeah, the plane can take off regardless...[/b] Originally posted by porsche996: The plane takes off in approximately the same distance necessary on a conveyor belt as it does on a regular runway.
Since Blue-Sky is mentioning his 20 years "aviation" experience, I guess I'll throw mine into the hat, even though it too has no bearing on the problem... I'm an airport designer. Civil Engineer. I design Runways, Taxiways, Aprons, and all things associated except the electrical & navigational equipment. I've been doing this for 6 years, now.
I assure you, the friction of the wheel bearings does not matter to the plane taking off. How's that? Because different surfaces have different coefficients of friction already. Asphalt runways have different coeff. than concrete. Significantly different on paper; absolutely no difference in the real world. Why's that? Because both numbers are so small in relationship to the take-off thrust of any aircraft that it doesn't matter.
[b]READ BELOW COMPLETELY FOR AS SIMPLE AN EXPLANATION AS YOU CAN GET ON WHY THE AIRPLANE WILL TAKE OFF
An aircraft's engine PUSHES (jet) / PULLS (prop) the aircraft along the ground. This results in a horizontal force on the axles of the aircarft because they are fixed rigidly to the aircraft. The by-product of this force is it causes ROTATION of the tires around the axles. The tires do nothing more than rotate around the axle; they do not cause any horizontal movement.
If a conveyor belt were under the tires, it too would cause rotation of the tires around the axles. But, it can not cause any movement and/or restriction of movement of the axles, as the tires do nothing but free-spin around them. Again, the conveyor belt spins the tires, but does not exert any horizontal force on the axle. You can test this "theory" by jacking up your truck (get a whole axle up in the air), and spinning a free-wheeled tire from below. The tire will spin, but the truck will NOT move. This is not because you aren't spinning the tire fast enough; spin it as fast as you want, and the truck still will not move. The truck can't move, because all the force you apply goes into spinning the tire; none of it is a horizontal force on the axle.
Summing the forces in the horizontal direction gives you a positive force from the engines, and 0 negative force, as the conveyor belt can not move the axles of the plane regardless of how fast it spins.
From Newton, Force = Mass x Acceleration. So divide the sum of the Forces (the engine force only as shown in the above paragraph) and divide by the Mass of the plane. What you get is the Acceleration of the aircraft. The friction is negligable, as it is an extremely small number compared to the Force.
The net result is the aircraft accelerates down the runway, and eventually obtains flight once there's enough lift provided by the air passing over the wings.
END EXPLANATION
And, it will reach its takeoff speed at the same distance down the runway as it would without the conveyor belt. The additional friction of the tires as they spin twice as fast is not enough to make a significant difference. Dynamic friction levels off at a certain point, and for all practical purposes remains a constant level whether the tire spins at 150 mph or 300 mph.
Editorial Comments...: While this is a physics, it's also a Statics & Dynamics problem. A problem like this would be taught in a 200 level Engineering Dynamics course, and any Engineer that can't answer it with only a fleeting glance ought to take some continuing education classes in a hurry...[/b] Originally posted by JeffW: Relevant information:
A plane is standing on a runway that can move (like a giant conveyor belt). This conveyor has a control system that tracks the plane's speed and tunes the speed of the conveyor to be exactly the same (but in the opposite direction).
Will the plane be able to take off?
Let's agree on what assumptions are sensible then. All of the assumptions below apply to virtually all aircraft.
Plane is powered by engines that push air (props or jets) Plane's speed is measured by a windspeed meter as well as GPS Plane's wheels spin freely Wheel friction is negligible when compared to thrust Newtonian physics apply
Coefficient of dynamic friction:
Force of friction:
F(f) = -uN
(negative because it opposes motion)
u = coefficient of static friction
N = weight of plane
Notice velocity is not included!
That means that the velocity of the conveyor belt is irrelevant for all practical purposes.
F(t) is force of thrust
a = (F(t)+F(f))/m
You won't find a scenario where |F(f)| is greater than |F(t)|. Therefore, in ALL cases the plane moves with respect to the atmosphere, thus achieving lift.
Possible scenario:
t = 0 :
Plane 0 mph Conveyor 0 mph Wheels 0 mph
t = 15 :
Plane 60 mph Conveyor 60 mph Wheels spin @ 120 mph
t = 55:
Plane 160 mph Conveyor 160 mph Wheels spin @ 320 mph
Either learn why it is correct or refute it....
..scientifically.
#607527 - 11/11/07 08:30 AM
Loc: Ft. Bragg, NC
Once again, you are not taking into account relativity. From your explanation, the plane will fly because it is moving forward relative to a fixed point in space. By that method, the treadmill is irrelevant to the question. It simply becomes will the plane fly once it reaches a certain speed as observed form a fixed point in space. Of course it will. Now, if observed from the treadmill, which is where I take it the speed is measured from, then the plane is sitting still in space. The plane is maintain its speed relative to the belt, NOT to the surrounding air and space. If it accelerates, then it has moved beyond the speed of the belt beneath it and thus moved forward in space.
#607528 - 11/11/07 09:12 AM
Now you are making assumptions and distorting the actual problem at hand. It's been proven that plane takes off and relativity does not matter because relativity has no effect on the forces at hand that do make the plane lift off.
#607529 - 11/11/07 09:31 AM
infx, The problem does not state that the plane matches the speed of the belt, it says that the belt matches the speed of the plane.
"Relativity" has fuck-all to do with it. No E=mc'2 here.
The casual observer not on the conveyor would watch the plane take off as any other plane on a normal runway would.
The conveyor cannot keep the plane in place because it exerts force only on its wheels, which rotate to negate friction.
A plane with its gear locked up, if it powered up, would move forward on a fixed surface. It would not be smooth, but it would move. Trust me. Now is that more or less friction than the conveyor acting on free spinning wheels?
#607530 - 11/11/07 09:50 AM
Relativity can be brought in play, but from that standpoint what matters is the motion of the plane relative to the air particles that provide the lift.
The engines will cause the plane to move forward relative to the air around it, so it takes off. (assuming the wheels are spinning freely, so the spinning conveyor belt is helpless to counteract the force of the engines' thrust against said air particles.)
#607531 - 11/11/07 09:50 AM
Loc: Mt. Zion, IL
#607532 - 11/11/07 10:15 AM
Ok, Lets forget all the analogies. Dynos arent a good example, they only move the wheels. A treadmill will move the whole object.
How about the analogy of a plane on a treadmill.
A plane sits on a treadmill, on a calm day, no wind, it is 72 degrees. There is a tree in the ground next to the plane even with the tail. Now, the treadmill starts to move, the plane starts to move backward on the treadmill. The pilot looks out his window and sees the tree moving from behind him towards him, as the plane is moving backwards on the treadmill. Now the engines start to push the plane to the speed of the treadmill, the tree is now even with the pilot as the engines push the plane, to be even with the tree, on the treadmill. Now as the engines push more the treadmill goes faster, the pilot can look out his window and see the same tree, not moving. The engines push faster, the treadmill moves faster, the tree is still even with the pilot as he looks out his window. The air around the wings of the plane is as still as the trees next to the plane, the pilot can move his flaps all he wants, he does not have the air resistance to take off.
#607533 - 11/11/07 11:09 AM
All you're doing is creating a bit of a tail wind, which the plane's engines will quickly over come.
Unless the pilot throttles back to intensionally not overcome the tree.
How about this, instead of slowly starting the tread mill (with the plane at rest), have it start suddenly/quickly with a jerk, like yanking the table cloth out from under a set table. The planes' inertia will keep it from moving backwards and the wheels will just spin on the tread mill while the plane stays motionless relative to the tree.
#607534 - 11/11/07 11:17 AM
Hey Chump.
Please explain how a treadmill rotating the wheels on an aircraft can counteract the force of motion of the plane generated by the plane's engines.
Seriously. Please explain this. It is a physical impossibility that a 1st year physics student must learn in order to pass the course. It's a very simple relationship of forces and moments. A moment (spinning the tire) can NOT cancel out a Force. You sum the FORCES in all directions, and you sum the MOMENTS in all directions. But you can NOT add/subtract a MOMENT from a FORCE. They are two different physical things.
Please, before you continue spouting your insanity, PLEASE do yourself a favor and learn the definitions of forces and moments, and how they are used with regards to motions of an object. Maybe, just maybe, once you figure that out, you will be able to understand why the plane can take off. Until you understand the differences in those two properties, however, you're going to continue walking around with your head in the sand.
So with that, I'm done. If somebody can't understand the simple logic between a Force and a Moment, then they can't have a logical conversation on this simple physics problem. And talking with an idiot only makes everybody else feel like an idiot...
