#572071 - 18/09/06 09:40 AM 4wd conversion
Looks like somebody finally did it .
I'm surprised he hasn't posted about it! [Huh?]
#572072 - 18/09/06 10:16 AM Re: 4wd conversion
I did it 8 months ago. [ThumbsUp] Just trying to get some stuff out of the Garage. neen to make room for my next project.
#572073 - 18/09/06 01:48 PM Re: 4wd conversion
Good work!
2wd'ers have been asking about that since this forum began. You should start a thread to tell everybody all the details!
#572074 - 18/09/06 01:53 PM Re: 4wd conversion
No point in it every time someone one brings up the subject all they get is BASHED by everone that they should have bought a 4X4 or some other type of BS.
#572075 - 18/09/06 02:07 PM Re: 4wd conversion
With the first Gen it is possible, should all be basically a bolt in. And if you do it yourself it should be cheaper than a trade in.
The second Gen sure it is possible but there is so much electronics that have to be changed.
How about a part list and an estimate on the parts cost?
#572076 - 18/09/06 02:24 PM Re: 4wd conversion
Perhaps so.
But now that it's been done, that should stop.
C'mon, post details!
#572077 - 18/09/06 02:39 PM Re: 4wd conversion
OK here goes This is for a frontier which is basicly the same as an Xterra this will work on most CrewCabs and DR's also. Cost that depends on how deep your pockets are I rebuilt most if not all parts with everyone SASing parts are cheeper now.I can not find all my paper work but ballpark I have about 2500-3K in it.
Parts List
1.Front diff = Had to buy all the mounting hardware new.
2. SLR Diff Drop Kit 150.00+ shipping (An Option)
3 Half shaft’s= Had to buy new mounting hardware
4 Knuckle’s = Replace rear seal
5 Rotors/ = Had rotors resurfaced and Replaced all seals and Bearings
6 Calipers rebuilt them and new Pads
7 Auto Hubs =Had to replace missing the C-clip and Star washer =18.00 Dealer
8 Warn Prem. Hubs =150.00 (an option)
9 The hub itself I had to replace 1 with new.= Hub 116.00 Dealer
10 Calmini Steering (An Option) package deal when I bought other parts
Also did mod to Idler arm 150.00
11 Replaced all Tie Rod ends. (not really needed but did it)
12 Transfer Case = Drained oil and replaced 200.00 from Ebay
13 Transmission = Drained oil and replaced filter = Filter kit 27.00=540.00 for the Transmission
14 Transmission cross member
15 Rear Transmission mount =50.00 From Dealer
16 Rear Drive shaft and Front drive shaft= Rear Drive shaft 130.00
17 Full skids= Skidrow skidplate = An option 540.00 from AC
18 LSD Mod to change slip tourq from 135+/- Ft Pounds to 230-260 FT pounds. 100.00
19. Shrockworks sliders 380.00
The things I still need/want
1.Front Bumper of some type
2.Winch
3.Rear or Ft.Locker
#572078 - 18/09/06 07:28 PM Re: 4wd conversion
where did you get the mod to change the slip torque on the LSD? Great post and good job on the conversion.. You have any plans to do an SAS?? Would be pretty cool to go from a 2WD to a SASed animal..
#572079 - 18/09/06 08:14 PM Re: 4wd conversion
If you have an LSD already what you need is a couple extra discs and Plates and a new spring plate and retainers. I have manuals for the Hard body and pathfinder the older Nissans have LSD's set up at 280ftlbs I copied them. I plan on doing an SAS next year some time. I am not sure if I want to do the Calmini Kit or do a leaf spring set up.
#572080 - 18/09/06 08:28 PM Re: 4wd conversion
#572081 - 18/09/06 11:25 PM Re: 4wd conversion
Nice Job! cool
#572082 - 18/09/06 11:30 PM Re: 4wd conversion
[ThumbsUp] [ThumbsUp]
#572083 - 19/09/06 07:23 AM Re: 4wd conversion
Kaiser Offline
Really, it looks like that is the way to go... looks like going from 2WD to SAS 4WD would only require slapping in a new transmission w/transfer case plus the rest of the stuff that a SAS usually requires anyway.
Was there any difficulty with the computer when switching trannies - or are they the same as far as the computer knows?
#572084 - 19/09/06 08:01 AM Re: 4wd conversion
No everything just bolted/plugged in with no problems the only thing that I had to do was make my Speedomiter(sp) cable about 12" longer.
If I did not have to have this as a DD I would have went the SAS way first but I am happy with what I have now.
#572085 - 19/09/06 08:04 AM Re: 4wd conversion
You should talk to the Goderators about making this thread a sticky. This is a question that has come up countless times. Now instead of being flamed, they can see how it's done.
#572086 - 19/09/06 10:10 AM Re: 4wd conversion
Well done!
#572087 - 19/09/06 01:42 PM Re: 4wd conversion
[b]where did you get the mod to change the slip torque on the LSD? Great post and good job on the conversion.. You have any plans to do an SAS?? Would be pretty cool to go from a 2WD to a SASed animal..
If you have an LSD already what you need is a couple extra discs and Plates and a new spring plate and retainers. I have manuals for the Hard body and pathfinder the older Nissans have LSD's set up at 280ftlbs I copied them. I plan on doing an SAS next year some time. I am not sure if I want to do the Calmini Kit or do a leaf spring set up.[/b]
I have the factory LSD, where can I find the info to do this mod, is it in a Hanes Manuel or is it somewhere else??
#572088 - 19/09/06 03:01 PM Re: 4wd conversion
I got all the information from a 95 pathfinder FSM also Brent help me with some of the part# needed. The Hanes Manuel should also have the break down in it not sure if it will have the Part#'s in it but. I have the FAST system on my home computer so I was able to plug in the Vin# from a friends Pathy and got the numbers for what is needed.
#572089 - 29/09/06 06:14 PM Re: 4wd conversion
OnlyOneDR Offline
I've only been wheelin' my converted truck for over 2 1/2 years already. Jeff, this was posted on XOC before but no one ever stickied this stuff, why I don't know because you're right everyone always asks.
My website and details are in the same place they have always been, in my signature...
http://www.noas4x4club.com/
#572090 - 01/10/06 09:44 AM Re: 4wd conversion
Nice job. Congrats man. Way to go. [ThumbsUp]
#572091 - 02/10/06 02:20 PM Re: 4wd conversion
You are the man yo! You have made things possible for the rest of us. lol, too bad your parts list alone has made me a little nauseas and frankly this type of job is way out of my abilities. I'd probably take my car apart, quit and fail to put it back together.
#572092 - 02/10/06 02:31 PM Re: 4wd conversion
Its not hard to do just labor intensive the worst part for me was getting the 2WD transmission out then installing the 4WD tranmission and transfer case. There are no special tools needed just a hub wrench. its all bolt in and if you have an FSM that will answer most if not all of you assembly questions
#572093 - 05/10/06 01:54 PM Re: 4wd conversion
Was doing the conversion still cheaper than it would have been if you had just bought a 4wd? Not bashing (I have a 2wd smile ) just curious.
#572094 - 05/10/06 02:39 PM Re: 4wd conversion
Kaiser Offline
Probably so since he got used parts and did all the labor himself.
It doesn't make sense to think "I'm going to save money by buying a 2WD and converting it later" but it might make sense to convert what you've got rather than trying to change vehicles.
#572095 - 05/10/06 03:43 PM Re: 4wd conversion
Trading my truck in was not an option it was paid for I did not want to start over with another truck payment so I converted it.If I could do it over I would have SASed it but at the time that was not an option for me it was my DD and I couldent have the truck torn apart that long.
As for how much it cost you dont want to know I have tons of upgrades and still need to get a whinch bumper and a ARB locker am I happy with the end result HELL YES
