by InfX708
20/01/25 05:54 AM
by InfX708
20/01/25 05:48 AM
07/01/25 10:27 AM
0 registered (), 229 Guests and 1 Spider online.
#572054 - 02/08/01 02:55 PM Lifting the front end, using torsion bars on a 2wd??
Rancher Offline
Loc: La.
hello,
Do the 2wd Xterra's have torsion bars?
If so, can u raise the front end using them the same as on a 4wd?
Has anyone here with a 2wd done this?
thanks!
Super black
2000 Xterra XE
Brush gaurd/Tail light gaurds;16" American racing wheels
Super black
2000 Xterra XE
Brush gaurd/Tail light gaurds;16" wheels
#572055 - 02/08/01 10:37 PM Re: Lifting the front end, using torsion bars on a 2wd??
Todrick Offline
Loc: Arizona
yes the 2wd's have torsion bars... yes you can raise the front using them...
HOWEVER, it will effect the stiffness of your ride.
i have not done it yet but will be in the next two months.... the tires i am putting on will not fit unless i give the torsion bars a couple turns...
i'll let you know how it turns out
whats worse than a guy in a room with a grenade?
throwing the grenade out and having it bounce back!
#572056 - 05/08/01 06:47 PM Re: Lifting the front end, using torsion bars on a 2wd??
PrimeX Offline
Loc: Houston, Tx.
Hello,
Yes they do.
Yes you can.
Yes I have, but I did this a couple of months back expecting to buy tires soon after. They ride is a tad more stiff, and the steering wheel has more of a loose feel when driving...What is the reason you're wanting to do this anyways? Also, if you raise them, it's a smart idea to get an alignment soon after.
It's just a message board people... lighten up!
#572057 - 21/08/01 11:32 AM Re: Lifting the front end, using torsion bars on a 2wd??
OKC-X Offline
Loc: Oklahoma City, OK
PRIMARYXTC26,
how may turns did you go when you lifted your front end? How much did it raise it?
OKC-X
"Sell crazy someplace else, we're all stocked up here."
(Jack Nicholson,As Good As It Gets)
#572058 - 21/08/01 05:52 PM Re: Lifting the front end, using torsion bars on a 2wd??
PrimeX Offline
Loc: Houston, Tx.
I ended up turning my right side about 8 turns, and the left 7...Gave me about 3/4" lift. Am about to install 32" BFG's, so I might be cranking them up a little bit more.
#572059 - 21/08/01 07:51 PM Re: Lifting the front end, using torsion bars on a 2wd??
adamsdell Offline
Loc: N. wilkesboro, nc 28659
DO YOU ALL HAVE A 2WD AND TRYING TO MAKE THEM LOOK LIKE A 4WD????
The fun thing about traveling, is driving my X
#572060 - 22/08/01 01:12 AM Re: Lifting the front end, using torsion bars on a 2wd??
Rancher Offline
Loc: La.
I (or should I say a 4x4 co.) lifted mine using an air gun. Raised it about 1 1/2 inches. Looks much better now that it is level. cool
Super black
2000 Xterra XE
#572061 - 22/08/01 01:25 AM Re: Lifting the front end, using torsion bars on a 2wd??
That's still just a wrench.
#572062 - 22/08/01 07:01 AM Re: Lifting the front end, using torsion bars on a 2wd??
Schludwiller Offline
Loc: Redmond,WA
Actually a $60/hour wrench. smile
#572063 - 22/08/01 08:11 PM Re: Lifting the front end, using torsion bars on a 2wd??
rrdstarr Offline
Loc: Tacoma
I cranked mine 6 full turns to clear my 31" TSl Swampers. I also have replaced the stock shocks with Bilstiens.
-Rick
#572064 - 23/08/01 06:22 PM Re: Lifting the front end, using torsion bars on a 2wd??
LamersX Offline
Loc: Fort Worth, Texas, USA
PRIMARYX, How did you raise your X's front end? What did you use? Did you do it yourself? How much did you life the front end? Did you lift the rear end as well?
Thinking about doing something like that? Let me know what you did!
Cheers!
Cheers,
LamersX
#572065 - 23/08/01 08:32 PM Re: Lifting the front end, using torsion bars on a 2wd??
Rancher Offline
Loc: La.
Actually the 4x4 co.(CAJUN OFFROAD) did not charge me. It took 10 min. and he was happy to help. He asked if I needed anything in the future to come and see him.
You should give it a try at a local shop. A another did the same got it done for free also. cool
Super black
2000 Xterra XE
#572066 - 24/08/01 01:51 PM Re: Lifting the front end, using torsion bars on a 2wd??
PrimeX Offline
Loc: Houston, Tx.
Cheers!
Yes I did it myself, it only takes a few minutes, but I had instructions just in case. I believe I got them from a post by Synchro, so you might see if it is still posted on his site? I am planning on ordering the add a leafs and shocks from EOE in about a month to have installed with my new tires. Do a search on this subject...I know for a fact there are others here who could help you out alot more than I can. smile
#572067 - 26/08/01 07:45 PM Re: Lifting the front end, using torsion bars on a 2wd??
PrimeX Offline
Loc: Houston, Tx.
Synchro, just a quick question? Those are the directions I used and had an off topic question? The picture you have posted on that url...What size tires/type are on the X in the picture, and were these pictures taken after you installed the 2" shackles? Thanks in advance...
#572068 - 26/08/01 07:52 PM Re: Lifting the front end, using torsion bars on a 2wd??
Synchro Offline
Loc: The booth on the left
Cheers!
my lift process goes as follows
1) adjusting torsion bars in the front up 1.5" for bigger tires and a little comfort room. (april 2000)
2) Aadded Rancho 9116 shocks in the rear (REALLY simple to install yourself) (June 2000)
3) SLR shackles (not sure if there is an i think gothamist has a howto on www.4x4lo.com . (january 2001)
4) Nismo torsion bars (schludwiller has instructions for this install on www.xterra4x4.com )(april 2001)
5) KYB front shocks (april 2001)
6) Rancho Add-A-Leafs (instructions on installing these can be found on the PNWX web site done by mosi) (May 2001)
I have since installed the AC front end pieces 2 weeks ago (all new upper a-arms, ball joints and bushings) to have a complete 3" lift kit. all i need now is longer front shocks but i am not spendig money on that right now after i just put in the KYBs. but i did it in stages as I had the cash not in one big plunk down for most lift kits. it ended up costing about the same too. this was best for me, cause like i said, as i had the cash, i upgraded it at my own speed.
[ 08-26-2001: Message edited by: Synchro ]
#572069 - 27/08/01 07:49 AM Re: Lifting the front end, using torsion bars on a 2wd??
PrimeX Offline
Loc: Houston, Tx.
Originally posted by Synchro:
32x11.5R15 BFG MTs.
happy to answer more questions.
One more here....I am about to purchase those same size tires (32x 11.5 BFG ATs) and was curious if you would advise purchase of the AALs and shocks and install with the tire, or wouldd it hurt if I installed the tires alone, and waited a few months for a better cash flow and install the AAL kit then? Anything you would advise ot warn against? Thanks again.....
#572070 - 30/08/01 06:42 AM Re: Lifting the front end, using torsion bars on a 2wd??
TravelingFool Offline
Loc: Prior Lake, MN
YOU FOUND A WORKING WENCH FOR $60/HOUR??!?!?! Oh, "wrench." Sorry.... frown
kjw &
the PNUTMNM
