Seeing how it’s been ~ month since I’ve completed the 1.0v SAS conversion I thought I would update this thread:
For the front axle rebuild I ended up replacing:
Inner, Outer Wheel Bearing & Races
Rotors, Calipers, Pads
Inner/Outer Passenger Tie-rods and Drive Outer
Dana Spicer Ball Joints
The front axle upgrades:
Long Field Super U-Joints
RockCrusher D44 Diff Cover/skid
ARB Locker RD116
Yukon 5.13 R&P gears
I spent about 7 hours total removing [rusty stuff, ton of grease all over the axle] rebuilding the front axle, grinding off the old shock/track bar mounts, and cleaning up. Used the following links for reference.
http://www.off-road.com/ford/bigbroncos/tech/dana44/ http://www.pavementsucks.com/tech/dana44hub.php The tools that I didn’t already have that I used where:
3/8” hex driver for the Calipers
DANA 44 spindle nut socket – 4 Prong 3 ½” long, 2 3/8” outer, 2 1/16” inner
I purchased all the bearing, brake, and hardware, supplies from my local parts store; AutoZone, tie rods from rockauto [a lot better pricing] and the rest from a couple vendors such as performanceoffroad that I had used in the past.
So far I have just installed the basic SAS kit and driveshaft and have the front swaybar and rear springs on order.
I spent ~ 12 hours on the rest of job total removing all the IFS stuff, cutting & grinding the upper shock mounts and LCA arm bracket, setting up the shocks/coils, bolting on all the cross members, skids, rear springs, shackles, driveshaft, brake lines, etc.
I did almost all the work myself with the exception of the arm welding & gear setup over a week’s period a couple hours at a time one weekend & at nights after the kids went to bed and whatnot. With a crew could easily be done over a weekend or less.
I used air tools, a good sawzall & grinder and went through a few blades & wheels. Helps to have some good sockets & box /open-ends but I mostly used 9,21,22mm sized stuff I recall with the occasional bigger size for the jam nuts n the arms or the track bar bolt. Two floor jacks helps move the axle around, the creeper will save your back some, and mechanic gloves for the hands.
Overall IMO I don’t think this SAS kit could be easier and well with the ability of average shade tree mechanic [or hack
] like me. If you can install a lift & steering system and don’t mind a little cutting & lifting than this kit is no problem.
I wanted to take a moment to give
to CALMINI for the great product and outstanding support I’ve received recently on their SAS kit because I really feel like they did the best job possible and I like to acknowledge excellence.
Each time I called the staff was very nice, prompt, and helpful and they went the extra mile to go over every fine detail even after hours if needed. If I ran into sometime, had any issue, question, or whatever somebody would take care of me. I don’t think I ever have received this level of customer support so quickly from any other after market parts vendor and I’ve dealt with many of them over the years. They really showed me that they cared a lot and even rushed shipped stuff to meet my sometimes time demanding requests.
I’m not going to rehash much of a review because one already been posted: http://www.xterraownersclub.com/ubb/ultimatebb.php?ubb=get_topic;f=1;t=009422
I’m really happy with the CALMINI kit so far; the ride is nice, firmer than stock up front but not as stiff as a 3” lift. Very quite overall, if it wasn’t for the swapper aircraft tire hum I don’t think I would hear anything.
The turning radius is slightly larger than stock but still fine, the steering is different than the stock IFS but a lot like the other solid axle front trucks I drive.
I’m going to add the front sway bar mostly for driving on the highway at speeds, I can mange now but I’m sure I will like it better with one.
I’ve been really impressed with the front kit off-road in the rocks and whatnot; lots of flex, very stable, and controlled at slow speeds. For faster more Baja type stuff I may end up adjusting the valuing/bleed on the shocks to firm things up a bit, but that’s really a personal preference. I ended up going with the stock valuing since the custom one was back ordered and getting the shocks myself, allthough I know CALMINI sells the custom one and runs that one on thier Yellow 01'
As far as my original budget I actually ended up spending less that I had planned about $5,500 so far on everything: Basic kit, coils/shocks, driveshaft, dual ARB lockers, 5.14 gears, rear shocks, $400 in labor for welding, gear, locker setup, tools, misc supplies.
If anybody needs part numbers or more details/pics let me know and I’ll do my best
Brian
