Originally posted by socalpunX:
XR - Do your class restrictions allow you to add a wishbone type upper link as long as you stay with the stock concept leaf suspension?
With your shock/spring package did you guys increase the ride height?
More spring rate? How is your shock valving?
The class rules will not allow any strengthening or modifications. They do allow use of 2 shocks per wheel, any location, can not protrude through the hood or floor. No remote mounting or lever mounted shocks.
Must use stock spring hangers and design. They do allow the semi coil over type shock like the X have up front to be made into full coil over shocks.
Spring rates are open. I have done 5 coil rate changes since leaving stock. Finally I have a stiff enough spring to race on.
National Springs had the expertise to nail the rear leafs the first try. I did step them up the last front rate change to make overall ride even.
Ride hieght is as close to stock as I could get. I did equal to a 1" body lift when I went solid with the body mounts. The suspension rides about mid droop, to keep wheels following the ground. It is set up like most quads are, you can pick it up from the frame and the tires will stay on the ground for several inches. The difference is the X does not squat when we get in.
After the first race I sent the shocks back to FOX for more valving. They also went to a new oil in the shocks. No complaints, shocks worked awsome the last race and testing.
I hope I answered all your questions. If you want to know more just ask.
