Good morning,
Even after an alignment, my truck is pulling to the right. Tire pressure is equal all around and there is no brake grabbing. I searched and found one thread that mentioned a worn idler arm bushing could contribute to a pull and a steering wheel that's not set straight.
However, it was only one post that mentioned this type of symptom. Can anyone else chime in to help me verify this?
I have to get under there and wiggle things around to see what happens...hopefully this weekend I'll have time for that as well as an oil/coolant change.
If indeed the bushings are worn, is a replacement as simple as pulling the bottom nut off the arm, swinging the arm out of the way and sliding new bushings in? I'm also thinking this might be a good time to put in the Calmini bracket if I have things off.
Thanks,
Bogatyr
2001 Nissan XTerra XE 40k
1984 Honda CRX 1.5 83k
1970 Land Rover IIa 88" 41k
1966 Land Rover IIa 109" 35k
