Yesterday at 10:44 AM
0 registered (), 239 Guests and 0 Spiders online.
#429067 - 03/03/01 05:05 AM sway bar disconnect question
blenderhead Offline
Loc: Grovetown, GA, USA
When you disconnect, do you just let the sway bar hang there, or do you have to remove the whole bar for 4 wheelin?
Blenderheads Xterra Homepage
Greg Moultrie
00 Aztec Red XE 3-pak
4x4 Auto
Greg Moultrie
4x4 Auto
#429068 - 03/03/01 07:18 AM Re: sway bar disconnect question
ShipRekd1 Offline
I have both my front and rear swaybar in my basement.....they have been there for about 6 months! Sure the X does lean like crazy...but once you get used to it you dont even really notice it. However, I had a buddy of mine tell me that every turn that I make it looks like I am gonna roll!!!
Jason
www.ec4x4e.com
#429069 - 03/03/01 09:09 AM Re: sway bar disconnect question
gothamist Offline
Loc: Virginia
If you're talking about the front (I assume you are), then all you need to do is yank the end links, you can leave the bar hanging there. It will occasionally bang into the A-arm, but it's no biggie.
gothamist -- MAXC member
http://www.beatdriven.com/xterra.html ---> moving to http://www.4x4LO.com
#429070 - 03/03/01 11:49 AM Re: sway bar disconnect question
blenderhead Offline
Thanks Goth....
Here is my attempt at a disconnect. Used the extra wing nuts from my Yakima adapters for easy removal and added urethane bushings.
Got a little drenched from the rain during my install, but I couldnt wait for it to stop.
[img]http://albums.photopoint.com/j/View?u=1479294&a=11140594&p=42582940&Sequence=0&res=high[/img]
Greg Moultrie
4x4 Auto
Greg Moultrie
4x4 Auto
#429071 - 03/03/01 08:45 PM Re: sway bar disconnect question
livinx Offline
Loc: Derry,NH
Where did you get the bushings and what size bolt did you use? Thanks for the info
