#428449 - 05/12/04 02:38 PM Calmini control arm ball joints??
for those of you who have the Calimini upper control arms and ball joints.....is the ball joints supposed to be mounted from the bottom with screws entering through the top of control arm or is the ball joint supposed to be mounted through the top of control arm with screws entering from underneath the control arm?......instructions are lost.
RJ
#428450 - 05/12/04 04:34 PM Re: Calmini control arm ball joints??
The missing instructions:
http://www.purenissan.com/np12500_install.htm
I have the SLR UCA's...but Daggerdoggie says:
The ball joints are mounted under the A arm, with the dome of the ball joint fitting in the large hole. Then the bolts go down from the A arm, through the ball joints. Use thread locker!
Hope that helps!
