0 registered (), 158 Guests and 0 Spiders online.
#424868 - 28/02/04 11:59 PM Tight Steering
After installing the 2 inch body lift my steering has become stiff. Before I could turn the wheel lock to lock with 1 finger sitting still. My air pressure is ok in the tires. Now it feels like rack and pinion with no power assist. It steers like my old 2x4 93 Nissan PU with no power steering. Is this normal due to a slight angle in the shaft now?
#424869 - 29/02/04 12:11 AM Re: Tight Steering
It sounds like the body lift is the culprit, but that's far from normal.
#424870 - 29/02/04 08:04 AM Re: Tight Steering
Miikkaa Offline
Loc: Central New Jersey, United Sta...
Hey KAHKI X,
Just a thought, but did you loosen the clamp bolts on each end of the steering shaft during the install?
Best regards,
Michael AKA Miikkaa
Earth people suck.
#424871 - 29/02/04 06:47 PM Re: Tight Steering
Yep, I lossened both sides and made sure the shaft was in each end. I took up the difference between both ends.
