0 registered (), 165 Guests and 0 Spiders online.
#418952 - 29/10/04 09:15 PM Idler Arm Brace Install help
I have searched and found only one match for my situation attempted the directions to correct it but with no luck, the post is a couple of years old so I hope new ideas will help.
I am attempting to install an IAB but i cannot remove the three nuts holding the arm to the frame I have wacked at them with a BFH and no luck. The nut located at the base of the Idler arm is no problem but the three others are killer.
**Sorry Ian don't mean to jack you photo from your broken IA but I just wanted to be specific. Hope you don't mind.
#418953 - 29/10/04 11:24 PM Re: Idler Arm Brace Install help
Those other 3 are only on there with 50 or so pound feet of torque, and should just spin off if you are holding the bolt on the other side with another wrench.
#418954 - 31/10/04 05:37 PM Re: Idler Arm Brace Install help
That looks like it hurt a little
