#418821 - 17/07/03 07:50 AM Front end vibration
After I had my new tires installed I notice that the steering wheel shimmies from 40-50 MPH. Before that and after that it is fine.
I had no problem at all before the tires. I don't know alot about front ends so is this more likely
A: Tires balanced incorrectly? or
B: Need for an alignment?
Any informed opinions will be greatly appreciated so I can take it to the right place to get it fixed.
#418822 - 17/07/03 08:03 AM Re: Front end vibration
austinbrtndr Offline
Loc: ATX
tires need to be balanced... steering wheel shaking has nothing to do with alignment... depending on wheels/tires, may be a PITA to balance, but it can be done... yours just weren't done correctly...
XOC
www.myspace.com/kraigslist
Kraig
#418823 - 17/07/03 08:57 AM Re: Front end vibration
Uzbad Offline
Loc: Durango, CO
Just balance & align them - vibration should go away.
#418824 - 17/07/03 11:24 AM Re: Front end vibration
Definately a balance issue. At 40-50 your hitting a critical rpm for the amount of unbalance in relation to the unsprung mass of your tire. A proper balance job should alleviate the problem.
#418825 - 17/07/03 04:19 PM Re: Front end vibration
Thanks guys, I'll take it back in for a re-balance tomorrow.
