The best thing to do is make yourself some quick releases that way you can take full advantage of the lift OFF ROAD, always keep the sway bar connected when driving on road. I used grade 8 bolts that were about an inch longer, a slightly longer center steel sleeve and a stainless steel knob to replace the normal nut that allows you to remove the links quickly and by hand. There are also plenty of people that have the stock swaybar links so it's up to you.
Fellow X'er,
Todd Frank aka FSRBIKER
"Not all Trails have a Bypass"
www.Extreme4x4Parts.com
sales@Extreme4x4parts.com
