23/04/25 04:06 PM
0 registered (), 74 Guests and 3 Spiders online.
#393401 - 16/03/08 08:02 PM Shrock Front Bumper and .....
Hi there,
Just an FNG here and wanted an opinion on what the best setup is for a shrock front bumper. I have heard that due to the extra weight it adds up front, it tends to lower the stance up front? I do want to put 285s on as well. I see that stillen is offering a leveling kit.
http://www.stillen.com/product.asp?id=STILVLKT01&c=SU&year=2006&make=NISSAN&model=XTER RA
would this along with a daystar 2" suspension lift front to back work? Would I need to use an AAL or just the kits offered in the link below with the leveling kit? Or would a 3" body lift be more appropriate? what would y'all suggest?
http://www.suspensionconnection.com/cgi-bin/suscon/KN09106X.html
http://www.suspensionconnection.com/cgi-bin/suscon/KN09105X1.html
thanks !
#393402 - 16/03/08 10:28 PM Re: Shrock Front Bumper and .....
The Shrock front bumper will push the front down at least an inch or more. IMHO, I would not use spacers up front if you're getting a Shrock front bumper. Instead, I suggest getting heavier-duty coil springs up front.
For the rear, a longer shackle will work. Some people have opted for an Add-A-Leaf (AAL) kit and/or shackles in the rear. If you go too high, you may need a shim in the rear to correct the pinion angle.
As for the 285s, I have read that they will fit stock with a minor "melt mod" to the plastic on the inner fenderwell. For more on this topic see either the 2005+ forum here or go to www.thenewX.org
