by Kerensky97
08/01/25 10:23 PM
07/01/25 10:27 AM
0 registered (), 159 Guests and 2 Spiders online.
#392334 - 23/09/05 10:52 AM Someone make us some LCA's
My ball joint boots are gettin a little dry rot... so it's going to be time for some LCA's soon.
Shrock, SLR, Calmini, SOMEONE make us some LCA's that don't wuss out at the shock mount and with a replaceable ball joint.
#392335 - 23/09/05 01:46 PM Re: Someone make us some LCA's
Can I get an AMEN!
#392336 - 23/09/05 01:50 PM Re: Someone make us some LCA's
Kaiser Offline
no kidding... having exactly the same problem.
I rubbed a little silicone grease on them to hopefully moisturize the rubber a little (is that stupid?).
Would smearing some RTV on them help seal up the holes and make 'em last longer?
The good news is that they aren't THAT expensive... $153 each HERE
#392337 - 23/09/05 01:57 PM Re: Someone make us some LCA's
Now that, is a good idea.
(Visualize the raising of a frosty cold pint of beer in salute of this idea, which I will be doing in the not so distant future.)
#392338 - 26/09/05 06:33 PM Re: Someone make us some LCA's
No more interest than this???? aww come on, you guys all know you need LCA's.....
#392339 - 26/09/05 06:42 PM Re: Someone make us some LCA's
OK OK stop yer bitchin.
I NEED SOME LCAs!!!!! Like PRONTO, no... wait... I just had em welded alll to hell.
SO GET THEM INTO DEVELOPMENT. So I dont have to weld again. :p
#392340 - 26/09/05 06:43 PM Re: Someone make us some LCA's
I dont need them yet since I have an '04 but i'm sure i will in the future.
#392341 - 26/09/05 08:35 PM Re: Someone make us some LCA's
ChuckH Offline
I'd like some; preferably by Calmini so they will work with the UCA's I already have!
#392342 - 27/09/05 08:19 AM Re: Someone make us some LCA's
I would love a lca that is about 1/4" to 1/2" longer then stock, and a lift uca to match it. this would get the 12.5's off the frame, factory lca, fuel line shield, etc.. A larger offset rim would just get me farther into the mudflap, and maybe sheetmetal.
#392343 - 27/09/05 10:01 AM Re: Someone make us some LCA's
So whats the deal with the LCA's? Do they also wear out with a lift?
#392344 - 27/09/05 10:31 AM Re: Someone make us some LCA's
LCA's wear out...they're a suspension component.
Ball Joints, etc...wear out...its just the way it is.
I think SLR has done a UCA/LCA set for long travel IFS on an X...and Total Chaos as well had done work on a system (no one I know hs either, but there are those here who have posted)
#392345 - 27/09/05 10:39 AM Re: Someone make us some LCA's
socalpunx Offline
Yes. SLR does make a LCA as part of the long travel/Stage 5 kit. If you're going to get it done get it ALL done right!
#392346 - 27/09/05 11:03 AM Re: Someone make us some LCA's
Kaiser Offline
Isn't that kit rediculously expensive, though?
I forget where I saw the price but I thought it was like $4000 or something...
#392347 - 27/09/05 11:10 AM Re: Someone make us some LCA's
socalpunx Offline
Hey now. I didn't say it was cheap, I just said that they make one. laugh
And the "kit" price does include shocks, shock hoops, bump stops, spindle extention , along with the billet uppers and HUGE boxxed lowers.
To be honest , if you looked at any high end kit like it from companies like Camburg or H&M it is a very competitive price.
I agree it's still expensive though.
#392348 - 27/09/05 11:27 AM Re: Someone make us some LCA's
Unless they have a different application.. that does nothing for you if you have 4wd. Notice there is no place for the front driveshaft.
#392349 - 27/09/05 11:36 AM Re: Someone make us some LCA's
socalpunx Offline
They have made the kit for a 4wd.
#392350 - 27/09/05 11:46 AM Re: Someone make us some LCA's
Yeah, for that kind of money just do the SAS.
#392351 - 27/09/05 12:00 PM Re: Someone make us some LCA's
Lets see some pics of that. I would be interested to see how they get that done.
#392352 - 27/09/05 12:12 PM Re: Someone make us some LCA's
socalpunx Offline
I don't have any pics but I know it was done.
I know the only reason why SLR hasn't released it along with pics is because there is a delay with the axle shaft manufacturer.
#392353 - 28/09/05 12:13 PM Re: Someone make us some LCA's
socalpunx Offline
Oh kay. Got some pics.
#392354 - 28/09/05 02:32 PM Re: Someone make us some LCA's
Kaiser Offline
It is for those people that are better served by IFS than by a SAS ('cause it costs about the same I think)... high speed desert running, jumping, mud etc.
I think most of us here would benefit more from the SAS - but this kit is pretty cool - and it has its uses.
#392355 - 28/09/05 04:11 PM Re: Someone make us some LCA's
xterra3202 Offline
Loc: Georgia
Am I assuming correctly that the SLR kit still uses the torsion bars??? I know total chaos has a replacment setup that uses coil overs....anyone know if it is a good kit and how much it costs???
Tim
Thomas Jefferson
#392356 - 28/09/05 04:23 PM Re: Someone make us some LCA's
socalpunx Offline
The TC is also a good kit. It still uses the OE pivots as well. There are advantages and preferences to both set-ups. Especially if you are going to still be using stock mounting points. With SLR's available 300M t-bars you can run a larger shock and still have a preferred spring rate.
#392357 - 28/09/05 04:31 PM Re: Someone make us some LCA's
socalpunx Offline
Back to the topic.
What would you guys want in an OE replacement lower arm?
If you get a OE length hand welded boxed lower with an easily replacable ball joint you are probably looking at something in the area of about $500-600. You have to appreciate that if you really want strength you are looking at a multi piece (cutting hrs. + man hours welding + matterials) arm that is essentially the same as what I posted but OE length instead of being 3 1/2 inches longer.
I know what I paid for mine but is it worth it to you guys to have one that's indestructable if it's going to be pricy?
#392358 - 28/09/05 05:22 PM Re: Someone make us some LCA's
indestructable with easily replaceable ball joints, yes worth the expense.
