"What fabrication is required for the rear shock hoop? Also, is there any type of seal to restrict the passage of noise, dirt, and water through the holes cut in the floor?" You must fabricate the sandwich plates to the frame. There are U-bends that come with the kit. You must cut the U-bends to length if you have a body lift (1",2",3" etc.). Your body height mount will determine the height you weld your sandwich plates to the frame.
There is no fabrication that is required on the lower mounts. We have designed a bolt on shock mount that bolts on to your OE sway bar mount. We are running a Bilstein 2.5 4-check bypass shock [shown on left].
We are currently having a mold taken off of our aluminum-built rear shock hoop cover. There will be production runs from fiberglass or carbon fiber.
Please call at 928.667.4757 or email at info@spencerlowracing.com if you have any questions.
>>>SLR
