by Kerensky97
08/01/25 10:23 PM
07/01/25 10:27 AM
0 registered (), 159 Guests and 2 Spiders online.
Page 2 of 2 < 1 2
#391739 - 12/01/05 07:21 PM Re: CALMINI Xterra/Frontier SAS Kit
Originally posted by Richard Krenn:
Carlton, what size R&P are you going to use?
Richard
4.88
#391740 - 25/01/05 06:23 PM Re: CALMINI Xterra/Frontier SAS Kit
Is anybody gonna do an axle flip in back to match the front lift?
It seems like a good idea; I just don't know if its possible....
#391741 - 26/01/05 03:21 PM Re: CALMINI Xterra/Frontier SAS Kit
chupasierras Offline
Loc: Monterrey, M�xico
Originally posted by DesertHB:
Make sure it’s from a mid 80’s Waggy, drivers side drop, 6 lug, no vacuum disconnect with disk brakes and you should be fine. I can measure my axle and give you the exact measurements if you need them.
Doug
What happen if it has vacuum disconnect? it will work?
Regards,
Abiel
www.abielg.com
#391742 - 26/01/05 07:58 PM Re: CALMINI Xterra/Frontier SAS Kit
DesertHB Offline
Loc: Huntington Beach, CA
[b]Make sure it’s from a mid 80’s Waggy, drivers side drop, 6 lug, no vacuum disconnect with disk brakes and you should be fine. I can measure my axle and give you the exact measurements if you need them.
Doug
What happen if it has vacuum disconnect? it will work?[/b]
It could be made to work, but I would keep looking for one without it.
-Doug
#391743 - 26/01/05 09:05 PM Re: CALMINI Xterra/Frontier SAS Kit
There is actually a way that the vacuum disconnect would be great.
If you spool the front end, then use the cable actuated disconnect (instead of the vacuum unit), then you could run it in 3 wheel drive (which works great actually!) and then just pop the disconnect to lock up the other front tire when needed. Much like an ARB, but you'll always have the left front tire moving when in 4x4, and will have the option to lock up the fourth at will.
If I run across a killer deal on a vaccy, then I'll use it. Spools are cheap as well. wink A lot cheaper than a locker in the front.
#391744 - 27/01/05 06:43 AM Re: CALMINI Xterra/Frontier SAS Kit
Chris Mc Offline
Loc: St Charles, MO
Have fun with that "steering thing"... wink
#391745 - 27/01/05 04:57 PM Re: CALMINI Xterra/Frontier SAS Kit
Been there, done that. With the vaccy actuated side disengaged, it's not a problem.
I have several friends welded front and rear. Not a problem, just an annoyance.
#391746 - 01/02/05 06:25 AM Re: CALMINI Xterra/Frontier SAS Kit
So how many people are planning on doing this SAS before goneMOAB?
#391747 - 01/02/05 11:38 AM Re: CALMINI Xterra/Frontier SAS Kit
Carlton, are you planning? laugh
#391748 - 01/02/05 05:31 PM Re: CALMINI Xterra/Frontier SAS Kit
Saline Offline
Loc: Fruita , CO
MMMMM Tax return!
Desert Solitaire
#391749 - 03/02/05 09:26 AM Re: CALMINI Xterra/Frontier SAS Kit
I thought the vacuum disco axles used a different carrier? You could still weld it, but aftermarket spools, lockers, etc would likely not work.
How about changing R&P gears to something an Xterra could actually use? The problem I see with that is that most waggys came with 3.07 or shorter gears...you need to replace the carrier to run 4.10 and lower. Seems to me that's where you'd run into the problem.
#391750 - 09/03/05 12:06 PM Re: CALMINI Xterra/Frontier SAS Kit
I just placed my pre-order! No word on when it will actually be available though. frown Now I just need to find the axle. Anybody know of a good place to find one in the San Francisco area?
#391751 - 09/03/05 02:33 PM Re: CALMINI Xterra/Frontier SAS Kit
Axle Offline
Loc: Fort Carson, CO
www.car-part.com
Axle
#391752 - 09/03/05 02:36 PM Re: CALMINI Xterra/Frontier SAS Kit
[b]So how many people are planning on doing this SAS before goneMOAB?
Carlton, are you planning? laugh [/b]
Yes... yes I am.
#391753 - 09/03/05 05:42 PM Re: CALMINI Xterra/Frontier SAS Kit
Richard Krenn Offline
Loc: Mount Vernon, WA, USA
3 questions
1. What is a vacuum disconnect?
2. How can you recognise you while at a junk yard?
3. Anyone got photos, dimensions?
#391754 - 22/03/05 08:16 AM Re: CALMINI Xterra/Frontier SAS Kit
datz510 Offline
Loc: Mesa, AZ
Some info I found regarding the disconnect.
The Waggie vacuum disconnect isn't on the axle tube, it's in the centersection with a big modulator attached in front of the diff cover.
its pretty hard to miss a vacuum disconnect axle.
The pumpkin should look just ike this one (this is my early bronco axle from my Pathfinder, but the pumpkins look the same):
The angled fitting on the top is for my ARB locker.. the one you are looking for will only have the vertical vent tube.
#391755 - 30/03/05 12:03 PM Re: CALMINI Xterra/Frontier SAS Kit
For those of you wondering, any 80-91 non vaccum waggy axle will work. I just picked up an '88 last night and am picking up an '87 tonight. They're identical in width and steering as the '82 waggy front on my Frontier. From surfing full size jeep boards, it appears the vaccuum disco was an option on '82-86 models only. Any '87+ axle is going to be a good find for this kit.
For those of you questioning gearing. You have to swap more than the R&P; you also have to swap in a carrier designed for 3.92 and lower gears. The stock 2.73's and 3.07's in waggy's use a different carrier. That's not an issue for those of you dropping in an ARB locker....that replaces the carrier all together.
Well, I guess it's time to get down to building my second D44. Might it find a home in my Xterra? We'll see.
#391756 - 15/04/05 10:03 AM Re: CALMINI Xterra/Frontier SAS Kit
What size tires can the kit handle?
When will the first batch be delivered?
Will there be subsequent batches (my X won't be ready for something like this until '06)?
#391757 - 15/04/05 10:07 AM Re: CALMINI Xterra/Frontier SAS Kit
33" are choice. As I understand it with a BL or trimming 35" will work.
Steve should answer that one. But as I understand it they will be available in time for those of us going to goneMOAB.
I am sure that once the kits are out that they will start keeping them in stock for people who are not wanting to do it right now.
#391758 - 15/04/05 10:45 AM Re: CALMINI Xterra/Frontier SAS Kit
Here's a manual disconnect kit for a vaccum disconnect axle.
http://www.collinsbrosjeep.com/main.htm
Page 2 of 2 < 1 2
