by Kerensky97
08/01/25 10:23 PM
07/01/25 10:27 AM
1 registered (Kerensky97), 135 Guests and 2 Spiders online.
#326935 - 20/12/06 02:09 PM 12/29 Steering system install
NOSUP4U Offline
Loc: Phoenix, AZ
Adam and I will be installing my Calmini steering system on the 29th, starting at 9AM at his place.
Anyone interested in watching/helping is welcome!
Mark
Thanks!
Mark (NOSUP4U)
#326936 - 20/12/06 02:33 PM Re: 12/29 Steering system install
BTW - I drink Bud Light or whatever you want Mark. [ThumbsUp]
#326937 - 20/12/06 03:29 PM Re: 12/29 Steering system install
NOSUP4U Offline
Loc: Phoenix, AZ
You got it!
Mark
Thanks!
Mark (NOSUP4U)
#326938 - 21/12/06 09:28 AM Re: 12/29 Steering system install
I may be able to swing by. I just installed mine with Dan a few weeks ago.
Make sure the wheel is tied securely.
#326939 - 21/12/06 11:53 AM Re: 12/29 Steering system install
I've done enough of those things. 2 hour job max including resetting toe. Make sure you have a 3jaw puller for that pitman arm and grease the heck out of the idler arm before you drive it.
To save money on an alighmnent, a tape measure and an extra set of hands is all that's needed to reset the toe. After installation, get the steering wheel straight and make your adjustments using that baseline. You should end up with about 1/8-1/4" of toe in for optimal tire wear - the steering install doesn't affect caster or camber. Make sure you have a common point of reference all the way around the tire, and each time you make a tierod adjustment, roll the truck back and forth a few feet before measuring again.
Another hint - break loose the tierod jamb nuts while they're still on the truck. Much easier. Don't forget that one on each side is reverse threaded.
For removing the TRE's, don't use a pickle fork...you'll destroy the boots. Pull the pins, remove the nuts, and hit the knuckle where the TRE goes through squarely a few times with a BFH, and they'll pop right out. You can do the same on the centerlink end (again, do this before you unbolt the CL and idler/pitman arms.
Happy wrenching!
#326940 - 21/12/06 12:28 PM Re: 12/29 Steering system install
Thanks Andy for the tips!
I never installed one before and wasn't sure what all would be included with the kit. I even tried Searching but was unable to find where someone documented the whole job. I don't think it will be that painful and I've taken many a TRE off without destroying it. VW Baja Days with bent steering components. wink
#326941 - 21/12/06 02:35 PM Re: 12/29 Steering system install
Something else that helps is to WD40 the crap out of the steering shaft above the pitman and let it penetrate for a day or two. Should make the pitman a little easier to get off.
#326942 - 21/12/06 05:11 PM Re: 12/29 Steering system install
You'll need (or should use) one of these- BFSOCKETS smile
#326943 - 21/12/06 06:15 PM Re: 12/29 Steering system install
We may run up for that. I have a harbor frieght nearby. Thanks for the find!
#326944 - 21/12/06 08:32 PM Re: 12/29 Steering system install
NOSUP4U Offline
Loc: Phoenix, AZ
If you can kind of describe exactly where/what that is, I'll do just that smile
Mark
Thanks!
Mark (NOSUP4U)
#326945 - 22/12/06 04:19 AM Re: 12/29 Steering system install
Go to Vatozzone and rent a 'Pitman Arm Puller'. I hear it is the right tool for the job...weird, huh?
Mark: Driver side, right where the idler arm would be if that side had one. WD 40 the shaft that points down to the ground with the arm on it. You will see some splines at the top.
FYI: The nut on the shaft is a real tough nut to crack. I had my full strength and body weight behind both mine and Dan's, no joke. Get a BIG wrench and a breaker bar for sure.
#326946 - 22/12/06 07:17 AM Re: 12/29 Steering system install
Kaiser Offline
My pitman arm was a breeze to remove... though maybe that was just because we had the right tools (THANKS NISSANNUT!!)... a 3/4" socket wrench and appropriate socket to get the nut off and a pitman arm puller to pop the arm off.
#326947 - 22/12/06 09:35 AM Re: 12/29 Steering system install
Tray answered your WD40 question.
I've done about half dozen steering installs....Xrock's Xterra was the worst one to get the pitman arm off...we fought that one. Mine were both pretty easy.
The 3 jaw puller from Autozone is what you need....don't get the little 2 jaw one - it's not big enough. I use that tool enough that I just bought one from them.
#326948 - 28/12/06 04:20 PM Re: 12/29 Steering system install
NOSUP4U Offline
Loc: Phoenix, AZ
Just bumping this thread. See you tomorrow Adam.
Mark
Thanks!
Mark (NOSUP4U)
#326949 - 29/12/06 09:51 PM Re: 12/29 Steering system install
Thanks for the Beer and I hope your alignment went well.
BTW - The system was very easy to install on the rust free components. wink
#326950 - 30/12/06 08:08 AM Re: 12/29 Steering system install
NOSUP4U Offline
Loc: Phoenix, AZ
Thanks Adam for the help. Pretty easy install in case anyone is wondering. I couldn't get in for the alignment so that what I'm doing today.
Bummed, wanted to get out and about today frown
Mark
Thanks!
Mark (NOSUP4U)
#326951 - 30/12/06 10:05 PM Re: 12/29 Steering system install
You definately missed out, maybe next time!
Check out our Pics and Vids. [ThumbsUp]
Web Album Link
#326952 - 02/01/07 09:09 AM Re: 12/29 Steering system install
Steering only affects toe. You could have done it yourself with a tape measure and saved yourself a few $$.
