Originally posted by Conundrum:
1. is likely to be the little plastic clip that holds the rod on the mechanisms inside the door that are attached to the solenoid or door lock knob. Most likely not electrical if you're hearing it.
2. is really wierd. I can only think that something is getting hot and like you would think it is a relay, most likely under the hood. Probably one for each - high and low - beams.
See ya tomorrow if you're going. I did take apart the door and check that, everything looks like it's in it's place and not broken. WIll probably check electrical connections sometime this weekend to narrow down the source, at least. Checked all fuses, when it came to the light, nothing blown, that's why I feel it's either a short in the wiring, a relay going bad or the multi-switch in the column, where the high beams are turned on at.
