#292587 - 18/08/05 08:32 AM '03 Aux In Project worklog
Hi, I'm just starting a worklog for installing the AUX-IN for '03 Xterras w/o the RF stuff.
I just picked up my 8-pin DIN plug from Fry's. http://shop4.outpost.com/product/2421710?site=sr:SEARCH:MAIN_RSLT_PG $.59
and my 6" mini-to-RCA adapter for $1.49.
http://shop4.outpost.com/product/4469286?site=sr:SEARCH:MAIN_RSLT_PG
I already have toggles mounted on the console.
Will post up pics and progess soon!
#292588 - 23/08/05 05:19 PM Re: '03 Aux In Project worklog
Thanks for that link to the DIN8 connector, I exhausted all of the local possibilities in 3 cities around me!
How's the install coming? As soon as I get my connector, I'll be pretty much doing the same thing as you smile
#292589 - 23/08/05 06:33 PM Re: '03 Aux In Project worklog
01SalsaXterra Offline
Loc: Suffolk County,NY,USA
I SUCK at soldering small pins. I tried and finally gave up with it..
I ending up coming up with this solution..
(Still working on splicing and wiring everything)
I picked up a 15' 8 pin CD changer cable off of ebay for $7.99.. Hacked it in half (I can actually make two now), used a multimeter to figure out which pin is which color wire. Wired the audio to a male 1/8" Gold jack. Just so I can plug my XM directly into the 01 Stock XE radio.
I'll see if it actually worked hopefully tomorrow..
I got "IT" from ebay.
Now it burns when I pee..
#292590 - 24/08/05 05:17 PM Re: '03 Aux In Project worklog
DOH!! Should have pulled out my radio before wasting my time on the adapter.. mad
The CD changer plug in the back of my radio is a rectangle 14 pin connector.. Doh!! confused
Anyone have a wiring diagram for soldering points on the pins? 01 Xterra XE, CD and tape deck..
#292591 - 30/08/05 03:39 PM Re: '03 Aux In Project worklog
Here's my buttons... mybad on the fuzzy pic
the middle button opens/closes my garage door and the far right button selects the AUX input for the stock radio.
Otherwise, this is the only other part that you can see.
