#292522 - 30/03/03 12:03 PM Fog lights- - - Help
VT SAE X Offline
Loc: PA
I read the thread from 3-27, however, i cannot for the life of me figure out how to get the f'in electrical connector sperated from the light housing assembly to pull it through the front. I already broke off where the connector is attached to the housing, i cannot get the two apart. Its the white or light gray connector. thank you
If it has tits or tires, it will cost you $$$
#292523 - 30/03/03 07:17 PM Re: Fog lights- - - Help
Rickster43 Offline
Loc: San Antonio,Texas
If you have the OEM Fog light Kit, it should be very simple, there should be a "tab-like" thing on the side of the connector, just use a screwdriver and try to release that tab, and in the same time try pulling the connector so it could be be released from the housing assembly...Good Luck..
Your Personal CADD Monkey...
#292524 - 01/04/03 09:41 PM Re: Fog lights- - - Help
magyar Offline
Loc: La Habra, CA
Also use a bit of WD-40 before separating the connectors. Good luck.
#292525 - 03/04/03 11:27 PM Re: Fog lights- - - Help
Costas Offline
Loc: Burnaby, B.C.
If the tab was on the other side, you wouldn't have seen it - definitely check that out.
Born to fish...forced to work!
