133
2
#268514 - 10/05/01 09:01 AM
32s & 33s - For the Love of God, Where's the Power?!
Loc: south lyon, mi
just installed 32" mud terrains. this was mainly an impulse buy - i do ALOT of off-roading, but in michigan, you just don't NEED 32s. but they looked great, sound good and i needed to write a $600 check to somebody. so i got 'em. then i tried to tow something. holy cow.
the xterra (even the 3.3) is pretty anemic whence it comes to power anyhow but with these tires, it flat out SUCKS (for lack of better vernacular). i was towing about 1000 lbs, and the thing would not hold 65 mph in overdrive. so i drove the 200 miles with OD off, resulting in an earth-warming 11 mpg. to me, this is rather pathetic for a vehicle supposedly capable of towing 5000 pounds. (even with stock tires, i would LOVE to see someone try and tow 5000 lbs). so my question is: what effect on power has bigger tires had, if you've made the switch. and, how are you mitigating the problem?
thanks
#268515 - 10/05/01 09:07 AM
Re: 32s & 33s - For the Love of God, Where's the Power?!
Loc: Virginia
Umm...uhh..."duh." Those tires are pretty heavy... So far no one has been able to regear that I've heard about--I don't know of any sources for a new r&p for the front diff (yet.) I'm running tires that are considerably heavier than stock as well and I just live with it. Don't really tow anything, though--if I did there's no way I would have a) bought an Xterra or b) bought big/heavy tires for my Xterra. You can try some of the performance upgrades, intake/exhaust, maybe even headers...beyond that...going to have to live with it if you want the clearance & footprint of 32's. Sorry.  ------------------ Vikram/gothamist -- MAXC member http://www.4x4LO.com
#268516 - 10/05/01 09:09 AM
Loc: D/FW Metroplex, TX
You lost lots of power going to the bigger tires. The only solution is to modify the gearing or change back to smaller tires. If you carried aq GPS you would notice that your speed is also not correct.....Your speedometer will err onm the low side, so at 65, you could very well have been doing 75+
Back in Network Administration! Bought a house, might get to play again soon!
#268517 - 10/05/01 09:19 AM
Loc: south lyon, mi
yes, good point, griffin. i was never sure whether the speedo would show on the low or high side with an increase in tire size. i guess i just wasn't anticipating such a big hit on power.
thanks for the tip.
[This message has been edited by fakie99 (edited 05-10-2001).]
#268518 - 10/05/01 09:23 AM
Loc: Brooklyn, NY
Originally posted by Griffin2020: ...If you carried aq GPS you would notice that your speed is also not correct.....Your speedometer will err onm the low side, so at 65, you could very well have been doing 75+
That is not 100 % true for every one. My truck was off with stock tires and was exsactly right with 31 inch tires so every ones spedometer may/IS different ------------------
#268519 - 10/05/01 09:42 AM
Loc: San Diego, CA
Originally posted by gothamist: Those tires are pretty heavy... The weight of the tires isn't a huge issue. It may be an issue when accelerating, but not once you're up to speed. Though the added rolling resistance is huge. It takes a lot to overcome that. Plus, as it was mentioned, two inch bigger tires is a huge increase in overall gear size. And as Griffin said, your speedo is probably far off, at least from what it read with the stock tires. ------------------ Eric Konarske & Lara, my X '01 Solar Yellow XE 3 Pk. 4x4
#268520 - 10/05/01 09:45 AM
7
Loc: AZ
Ok, now that we know that the speedo may be off. How does one calculate the speed if you don't have a GPS. And don't tell me to buy one because it isn't in the cards right now. ------------------ http://www.gpxo.org
#268521 - 10/05/01 09:45 AM
Loc: San Diego, CA
You're right. With my 31s my speedo is more accurate than it was stock, but when you're comparing power loss with stock tires the difference is what's important--not real world accuracy. ------------------ Eric Konarske & Lara, my X '01 Solar Yellow XE 3 Pk. 4x4
#268522 - 10/05/01 10:06 AM
Loc: san jose, CA, USA
In theory... MPH is calculated based on rotation of the tires. Now, for each rotation of the tire, the distance traveled is greater because of the larger tire circumference. Since tire circumference is linear with tire diameter, just take the difference in the tire size and divide by the old tire size. So, assuming original tire size of 30", (32-30)/30 = .0667. So, your speedo reads 6.67 percent higher. At 65mph with the new tires and uncalibrated speedo, actual speed is 65/(1-.0667) = 69.6 mph. Actual results may vary based on true tire diameter (dependent on inflation, tread thickness, etc...). I think this is about right.
[This message has been edited by xterrabull (edited 05-10-2001).]
#268523 - 10/05/01 10:07 AM
7
Loc: AZ
Great now I gotta go back and take a math class just to figure out how fast I am going when I get new tires.  ------------------ http://www.gpxo.org [This message has been edited by DeFibVT (edited 05-10-2001).]
#268524 - 10/05/01 10:12 AM
Loc: Virginia
Originally posted by ILUVMYX: The weight of the tires isn't a huge issue I disagree. Even if you kept the same overall tire size, weight of the tires/rims makes a very noticeable difference in actual and perceived power. The only fun thing is that now I have so much rolling inertia I don't need to give the truck any gas on the highway going downhill.  ------------------ Vikram/gothamist -- MAXC member http://www.4x4LO.com
#268525 - 10/05/01 10:21 AM
Loc: San Diego, CA
Originally posted by gothamist: I disagree. Even if you kept the same overall tire size, weight of the tires/rims makes a very noticeable difference in actual and perceived power. The only fun thing is that now I have so much rolling inertia I don't need to give the truck any gas on the highway going downhill.
In perceived power only when accelerating. After that the only power loss you'll feel is from big fat squishy tires with a lot of rolling resistance. A quick story to relate my point. Bicycle racers are huge weight geeks. Especially when it comes to wheels/tires because rotating weight is roughly 4 times more noticable than non-rotating weight. But that's only for bikes that need to be able to accelerate fast. For the cyclists who attempt what's known as the hour record, they actually put weights in their wheels to make them heavier. The hour record is just to see how far you can go in an hour on a flat track where your speed stays the same for the whole ride. I guess in a case like that, where there is no acceleration, they feel that inertia is actually an advantage. And belive me, those guy wouldn't do it if they lost even a 10th of a second. ------------------ Eric Konarske & Lara, my X '01 Solar Yellow XE 3 Pk. 4x4
#268526 - 10/05/01 11:02 AM
Loc: Brooklyn, NY
Originally posted by DeFibVT: Ok, now that we know that the speedo may be off. How does one calculate the speed if you don't have a GPS. And don't tell me to buy one because it isn't in the cards right now.
when you drive on the highway try to find a smoth straight spot and look at the side of the road there should be ( on most highways) mile markers count how many mile markers you pass by while doing 50 miles per hour in 1 minute then multiply by 60 minutes and you will get roughly your true mph or better yet drive 50 mph for 10 minutes and then mupltiply the mile markers by 6 and you should get even more acurate figure or get GPS  ------------------
#268527 - 10/05/01 11:21 AM
Loc: Plano, Tx
Does anyone know what the gear ratio is at at stock? If you are wanting to change your gear ratio this website:http://www.differentials.com/njfaq.htm may help determine what you will need for that power gain that you are looking for.
------------------ Vince
Vince 2002 XE-V6 4X4 Silver Ice 5-Spd. "Bone Stock"
#268528 - 10/05/01 11:40 AM
Loc: Alexandria, Virginia
who tows with 32' tires? Dude, hate to say it, but *any* vehicle is gonna lose a drastic amount of power towing with that size tire. Ever see big fullsize dodges and Chevy's on the highway towing trailers or whatever? Look at their tires, their usually faily small, skinny tires. Not 32's or 33's. The trade off to running flotation size mudders is that you are commiting yourself to driving a trail rig, not a tow rig. If you need to tow frequently then I say just get another set of all season highway tires and have them put on when you need to tow.Or leave them on and have the mudders put on only when you know you are planning an off-road trip. Just my .02
------------------ 01 SE 4x4 Silver Ice
#268529 - 10/05/01 11:44 AM
Final drive ratio XE (V6): 4.363 SE: 4.636 Transfer gearratio (:1) 2.020 more specs at http://www.theautolink.com/Transcripts/Xtera_info.htm ------------------ 01 SE 4x4 Silver Ice
#268530 - 10/05/01 12:01 PM
Loc: Denver, Colorado
#268531 - 10/05/01 01:27 PM
I did a little test last weekend with my 32s. 50 miles covered (by mileposts) but 48.1 miles recorded. 2.9 miles short x 2 = 5.8% difference.
#268532 - 10/05/01 02:26 PM
Loc: Huntington, NY
The problem is simple... You have an automatic.  ------------------ 01 SE 6cyl 5spd Solar Yellow
#268533 - 10/05/01 06:06 PM
Loc: The booth on the left
i have an automatic with 32" BFG MTs and I can still beat people off the line if need be. i can cut people off with the best of them on the DC beltway if i have to. i have yet to tow anything though. maybe i am just not sure what you all are talking about to undestand, but this thing has plenty of power for my needs. the only thing i have swapped out is, i put a K&N air filter in. i know Mr T has towed his camper a bunch of places with his X. it's got 32" BFG MTs as well, but it a manual. ------------------ Synchro (aka Kirk) 2000 Alpine Green 4x4 Auto, ARB, Warn XD9000, 32" BFG MTs
#268534 - 10/05/01 07:08 PM
Loc: Portland, OR
I was able to hit 100mph (briefly) on I-70 on the way to Moab last month, and I have 32s. I was able to get a true speed reading from my GPS. My speedo really isn't that far off on the speed correction and they are new tires. The 5 speeds seem to have a higher correction than the ATs. I also had about 450lbs of extra weight from sliders, bullbar, winch, skid plates, and a bunch of camping gear. ------------------ 2000 Silver Ice 4x4, SE ARB Bullbar & air locker, 32" BFG Mud Terrains PNWX webmaster www.pnwx.net [This message has been edited by Mosi (edited 05-10-2001).]
confused previous X owner/then a previous Rover owner/ back to an X owner 07 Avalanche OR X 4x4
#268535 - 10/05/01 08:15 PM
Loc: Naples, Fl.
I am a Police Officer, oneday I played around with the RADAR trailer and my X. With stock tires it was anywhere from 3 to 4 miles per hour off. So maybe the bigger tires would then give a better reading. Would it matter if the X had bigger rims? Does Nissan change the gears for the larger rims? Or does the smaller rims get stuck with the other ratio? Or does it even matter?
------------------ Lawdawg 2001 XE 4x4 Cloud White
GO GATORS!!!!
Lawdawg
#268536 - 10/05/01 08:20 PM
Loc: San Diego, CA
Originally posted by Lawdawg: Or does it even matter?
Wheel size doesn't matter--just the OD of the tires. ------------------ Eric Konarske & Lara, my X '01 Solar Yellow XE 3 Pk. 4x4
#268537 - 10/05/01 08:41 PM
Loc: La Selva Beach, CA
Originally posted by OffroadX: 50 miles covered (by mileposts) but 48.1 miles recorded. 2.9 miles short x 2 = 5.8% difference.
Brent Don't you mean 1.9 and 3.8%?  ------------------ Patto Silver 2001 4WD XE 3 Pak w/mods
