0 registered (), 198 Guests and 1 Spider online.
#175628 - 09/02/02 05:57 PM Vertical Scratch
lemsip Offline
Loc: Lakewood, CO
I have read on here that I should buff out scratches by rubbing along the length of the scratch.
I dropped a snowboard when I was taking it off the roof and it put a nice vertical scratch in the paint.
Should I rub along the scratch ? or front across it in the direction of normal scratches in my vain attempt to make it disappear ?
Thanks.
#175629 - 09/02/02 11:57 PM Re: Vertical Scratch
Photo Trek Offline
Loc: Winston-Salem NC
well, I need more info on the scratch. First of all when you rub over it gently with a fingernail can you feel the scratch? If so name the scratch and become friends. If you can't feel the scratch the best way to remove it is with a high speed buffer and a medium cut compound followed by polish and wax. You can hand compound the scratch using a circular motion muchn like waxing but with more elbow grease.
The thing to remember is you actually remove paint when buffing out a scratch so the deeper the scratch the more paint that has to be removed.
Wet sanding is another option but if you are asking how to remove the scratch this is probably more involved than you care to do. If you are interested I can tell you the proper way to wet sand the scratch but if you don't know what you are doing you will do more damage than good. eek
Greg
www.446Photography.com
2000 Solar Yellow Xterra XE....Sold long ago
2010 Night Armor Xterra OR....Current ride
BFG AT KO's
#175630 - 24/02/02 04:09 PM Re: Vertical Scratch
Rspatafore Offline
Loc: Pittsburgh, PA 15237
I have similar scratches from a son's bike so it looks like i will be naming them now
2001 Silver Ice SE
#175631 - 24/02/02 09:03 PM Re: Vertical Scratch
mmUTK Offline
Loc: Knoxville, Tn
SEARCH for scratch or scratch removal.
I once supported meguires (sP) But now In the sunlight I have noticed the scratches I once thought were gone, are actually still there.
600$ to repaint (HA!) I don't think so...
http://www.firemarshall.net
