by InfX708
20/01/25 05:54 AM
by InfX708
20/01/25 05:48 AM
07/01/25 10:27 AM
0 registered (), 197 Guests and 1 Spider online.
#133074 - 06/02/06 07:21 PM Re-Order the search options?
Would it be a big deal to re-order the search categories/forum sections so that they perhaps match the order they appear on the board top to bottom, or alphabetically, or something?
When you pull down the options..there's no rhyme or reason to them....
and
The ones we want to search the most (Newbies) are the LEAST likely to figure it out/not give up.
#133075 - 06/02/06 07:39 PM Re: Re-Order the search options?
Here Here!
Unless you know where what you are looking for is you can't find it... [Freak]
#133076 - 06/02/06 07:42 PM Re: Re-Order the search options?
[ThumbsUp]
#133077 - 06/02/06 08:02 PM Re: Re-Order the search options?
Whoa! I was going to post the same sugestion. When you search, you have to manualy search for the forum. It wouldnt be so hard since they are out of order because usually on drop down lists you can type the first letter of the field you want but when you have this : >> infront of everything you cant do that either.
Thanks TJ
#133078 - 06/02/06 08:47 PM Re: Re-Order the search options?
I will look into that.
Good suggestion
#133079 - 06/02/06 08:54 PM Re: Re-Order the search options?
Ok.. here is the problem I see.
The board arranges the search order by the creation of each forum.
So unless I can find a workaround that does not include deleting all the forums and rebuilding the site we may be stuck with it the way it is.
#133080 - 06/02/06 11:15 PM Re: Re-Order the search options?
[Freak]
I have no idea what that means.
Can a subtle change in the forum name...like re-naming a forum, rather than deleting it....be performed?...in the approriate order of "Creation"?
Like space space name...?
Any other work arounds/band-aids?
We can program rockets that can hit asteroids...surely we must be able to program a board to present the search categories as we like.
#133081 - 07/02/06 08:06 AM Re: Re-Order the search options?
bdjones72 Offline
Loc: Buckeye, AZ
Is there a way to search the entire forum? A lot of times a question is asked and answered in a forum that it doesn't necessarily belong in. Also, as was mentioned above a newbie may not know what forum to begin searching in. A search of the entire site may spit out a lot of different results, but would be better than having to search each separate forum individually.
#133082 - 07/02/06 09:12 AM Re: Re-Order the search options?
ironically, you should search for that answer, I think it's been covered numerous times.
Something to the effect of sluggin' down the server for a few seconds by having to search every forum/post available.
#133083 - 07/02/06 04:11 PM Re: Re-Order the search options?
DocNo Offline
Loc: NoVA
Argh - I wish Ian hadn't given up on switching to vBulletin frown
Murderous Fire!
#133084 - 08/02/06 12:15 PM Re: Re-Order the search options?
KJ_dragon Offline
Loc: East Bay, CA
This has been suggested at least once every 4 months for the past several years. The basic conclusion is the same each time.....
Ian/Carlton doesn't have enough time to re-write the code to make everyone happy. So... their time > our happyness.
If anyone wants to volunteer to invest the hours needed to re-write and troubleshoot the code - I am sure Carlton wouldn't object to making the change.
#133085 - 09/02/06 06:09 AM Re: Re-Order the search options?
Funny, I did a search before suggesting it, and it didn't come up.
#133086 - 10/02/06 09:37 AM Re: Re-Order the search options?
Origami Gangsta Offline
Loc: Dammit! Even CLOSER to Smith a...
You could always just search from inside each section.
For example, if you wanted to search for something in General, just go into General and click the search button from there. It will automatically be set to search in General for you.
Or maybe I'm misunderstanding the question? I'm assuming you want all the sections on the universal search to be reordered in the way they are laid out on the main page?
This is how you post whore..
#133087 - 12/02/06 03:52 PM Re: Re-Order the search options?
seems to be the most logical way of searching.
#133088 - 13/02/06 04:22 PM Re: Re-Order the search options?
the problem I run across alot is the info not being in the specific forum I think it oughta be in
#133089 - 16/02/06 02:26 PM Re: Re-Order the search options?
How about a Google global search intergrated into the site?
That would solve everyone's problem
#133090 - 17/02/06 05:15 AM Re: Re-Order the search options?
oooh, thinking outside the box!
isn't there a way to go to google's main page and do a search specific to a site? I dunno if it catalogs forums that actively though.
#133091 - 17/02/06 05:37 PM Re: Re-Order the search options?
DocNo Offline
Loc: NoVA
Yup. If I were searching for headlights, I could type the following into google:
headlights site:xterraownersclub.com
site: restricts it to the domain specified
Murderous Fire!
#133092 - 19/02/06 06:50 AM Re: Re-Order the search options?
I thought it was the other syntax:
Code:
site:xterraownersclub.com headlights
But either one works.
http://www.askdavetaylor.com/how_can_i_add_a_google_search_box_to_my_web_site.html
http://www.google.com/searchcode.html
#133093 - 20/02/06 07:38 AM Re: Re-Order the search options?
Sounds like a sticky issue.
The site's search feature is very clunky and discourages use...if we just make sure that the google option is available as back-up, or as the starting point, I think it would help everyone.
