Yesterday at 10:44 AM
0 registered (), 140 Guests and 0 Spiders online.
#128633 - 16/05/05 07:29 AM CV
xterraintx Offline
Loc: Eddy, TX..
I searched Bayckyard mechanics but did not get a good answer. I changed oil this weekend and discovered a torn CV boot. Driver side at engine side.
Should I replace the entire CV or just the boot? Has anyone replaced just the boot? I already have a spare used CV but like having it for the trail.
I need to do whichever this weekend as I am going to Oklahoma for the Memorial day ride.
#128634 - 16/05/05 07:47 AM Re: CV
I have replaced them before.
If there is still grease in the boot and it does not look really dirty then you should be able to replace the boot and save the shaft.
#128635 - 16/05/05 08:19 AM Re: CV
Kaiser Offline
Keith is the KING of replacing half shafts... he'll be able to answer any questions about it (assuming the '96 pathy is close enough to the Xterra)
#128636 - 16/05/05 11:52 AM Re: CV
Aero Steve Offline
I don't seem to keep CV joints in one piece long enough to just tear a boot. I think Andy at nissan4wheelers replaced a boot on his Frontier while it was still IFS. If I recall correctly getting the new boot over the joint was a pain in the ass. Like Carlton said if it still has grease in it and doesn't look too dirty you should be safe with just changing the boot. I bought a set of spare boots from Xterraparts I've never been able to use. Both came with a packet of new grease.
#128637 - 16/05/05 02:13 PM Re: CV
xterraintx Offline
Loc: Eddy, TX..
I am going with the Autozone half shaft (lifetime warranty )
What size axle nut is on them... is it out of the ordinary... what do I need?
#128638 - 17/05/05 07:40 AM Re: CV
Kaiser Offline
There isn't a nut - at least not on the wheel side of the thing... just a C clip that keeps it from coming out of the hub.
#128639 - 22/05/05 03:44 AM Re: CV
xterraintx Offline
Loc: Eddy, TX..
I give Carlton credit for changing his CV at GOX a year or two ago smile Mine went OK but was in the garage with all the tools I needed.
Would not like to do it on the trail or even the campsite.
#128640 - 22/05/05 08:21 AM Re: CV
Aero Steve Offline
Roger,
I changed the drivers side at goneMOAB last year at Ian's condo and I've done a the passenger one on the side of the trail before. In both cases the only thing I didn't have (but was able to borrow) was a floor jack and jack stands. I can do it without them, but it makes life easier to have them.
#128641 - 22/05/05 08:37 AM Re: CV
[Wave] Roger (and Steve), nothing I'd wanna' do on a trail, but I did one of mine in a garage not too long ago.. This is from that post-
Replaced one today (passenger side).
-Removed hub
-removed snap ring
-loosened UCA ball joint bolts
-removed brake caliper (piston held open w/ zip tie); set on UCA out of way
-removed steering stop bolt (to allow rotor to move forward further)
-removed bottom shock bolt, and loosened top nut
*all of that allows LCA to drop providing enough room for insertion*
-removed remainder of grenaded interior cage
-Slid new assembly into place
-replace bolts into cage
-replace snap ring
-replace hub
-replace ball joint to UCA
-replace brake calipers
-replace steering stop bolt
-tighten shock back down
Here's a link to the carnage- Inner cage destruction
I'm bringing an extra assembly (and other stuff too :rolleyes: ) to GONE, so rock on! [ThumbsUp]
#128642 - 23/05/05 06:51 AM Re: CV
xterraintx Offline
Loc: Eddy, TX..
Dan, I wish i'd read this before starting smile we tried doing it without removing too awful much frown We finally just did as you did to get it out and the replacement back in.
Had to replace the UCA bushings anyway so we pulled it too.
Now I have idler arm bushing to get and replace.
#128643 - 23/05/05 09:24 AM Re: CV
Aero Steve Offline
Nice work, Dan, blowing up the inner cage. smile I've snapped the shaft at the outer joint and grenaded 2 outers, but never an inner.
