0 registered (), 307 Guests and 0 Spiders online.
#110510 - 16/04/08 04:18 PM Hollister Hills SVRA : 2 wheel drive...
I've never been to the Hollister Hills SVRA park. But I've heard lots of cool things about it. I just found out that 2 wheel drive trucks are not even allowed to use the Green Circle (easiest level) trails.
Is it worth the trip for 2 wheel drive Xterras? Can I at least play around on dirt trails in a 2 wheel drive truck? I just want to go turn up a little dirt but not hurt anything....
- Kareem
#110511 - 17/04/08 12:26 PM Re: Hollister Hills SVRA : 2 wheel drive...
I didnt know that they checked for 4wd. From my experience, most of the green trails were just cat walks. You didnt really need 4wd to go on them. Well, as long as it wasn't raining. You should be fine.
#110512 - 17/04/08 11:17 PM Re: Hollister Hills SVRA : 2 wheel drive...
They don't check whether or not your truck is 4wd or not. Basically its on you if you F*ck up your truck. I have been out there a few times in my 4x2 and have done just fine. Take a look at some footage of my truck back in Nov.
http://youtreadtube.com/item/5BKXQ7GBDHDWCS65
I do recommend that if you decide to go bring someone that can pull you out!!!
#110513 - 18/04/08 02:35 AM Re: Hollister Hills SVRA : 2 wheel drive...
I cant believe you did that ravine in 2wd. I did it in 4wd and even that was hard enough. haha. Great video.
#110514 - 18/04/08 02:56 AM Re: Hollister Hills SVRA : 2 wheel drive...
I believe you can even do blues, just with better tires
#110515 - 18/04/08 07:52 AM Re: Hollister Hills SVRA : 2 wheel drive...
Well let me tell you, I didn't have 4wd or off road tires but the clutch took one hella of beating.
#110516 - 21/04/08 08:39 PM Re: Hollister Hills SVRA : 2 wheel drive...
Ok. Now I'm scared.
Well, are there other places in the area where one can play around with their more docile Xterra?
- KAreem
#110517 - 21/04/08 10:38 PM Re: Hollister Hills SVRA : 2 wheel drive...
i want to go. ummm theres a 2wd friendly place past yuba city. prairie hills i believe?
#110518 - 22/04/08 09:07 AM Re: Hollister Hills SVRA : 2 wheel drive...
Roxy,
Prairie Hills sounds cool. When was the last time you were there?
- Kareem
Moderator:  Huey, slamson00
