#101326 - 06/01/01 08:25 PM Top Speed In 4H?
drspencer Offline
What is the fastest you can travel in 4H with an auto trans?
Thanks.
#101327 - 06/01/01 08:43 PM Re: Top Speed In 4H?
bn300 Offline
Loc: Buffalo, MN
55mph max. Any faster and I would wonder what the hell you need 4x4 for, when clearly you can walk on water.
If it merits 4 wheel drive, it does not merit any faster speeds.
Unless of course, you have a Porshe 928 w/awd!
I got nothin'
#101328 - 07/01/01 01:08 AM Re: Top Speed In 4H?
No problems doing 70+ on dirt roads in Moab last Fall.
I don't recommend it unless you've been driving 4WDs and AWDs for a while.
#101329 - 13/01/01 01:02 AM Re: Top Speed In 4H?
KCX Offline
Loc: Kansas
I did 65mph on a 3" inch snow packed interstate with ease. The rpms nor the engine was indicating any struggle. The Xterra rules in snow with 4WD!!
www.hxoc.net
#101330 - 16/01/01 10:50 PM Re: Top Speed In 4H?
deanf Offline
Loc: N47º 06’ x W122º 22’
Why so fast? 'round here it's known as "too fast for conditions" and can get you a ticket.
"Anyone feel like saluting the flag which the strutting ATF and FBI gleefully raised over the smoldering crematorium of Waco, back in April of ‘93?" - Vin Suprynowicz
I'm a constitutional fetishist.
#101331 - 27/01/01 12:56 AM Re: Top Speed In 4H?
KCX Offline
Loc: Kansas
Not when the cops can't get to you in there 2wd Crown Vic's! Besides, it was 200am and not a soul in sight....
Join the Heartland Xterra Owners Club!
www.hxoc.net
www.hxoc.net
#101332 - 29/01/01 07:08 PM Re: Top Speed In 4H?
AviatorJud Offline
Loc: Nashville, TN, USA
I was under the impression that the 55mph max was the max speed that you could be going when you shift into 4H. I thought that once you were 4H, that you could go faster, not that you would ever really NEED to go faster in 4H. Please correct me if i'm wrong.
-Judson
-Judson Mulherin
Future X Owner
#101333 - 29/01/01 07:28 PM Re: Top Speed In 4H?
electrobuzz Offline
Loc: Denver, Colorado
Judson --
Per the Xterra manual the max speed to shift from 2h to 4h is 25 mph. Maybe you could shift at 55 -- tho when I imagine that I just get visions of the tranny grinding into oblivion.
The manual states a 55mph cap for driving in 4h, tho this weekend, I drove at 65 in 4h. It seems that if there is a little slip, it can't hurt to be able to compensate with both axles.
Dan.
#101334 - 29/01/01 07:50 PM Re: Top Speed In 4H?
My 1988 4Runner did 75+ in 4Hi no problem.
There really is no limit for 4WD in any vehicle I am aware of. The front end turning is not different than the back end turning.
Regards,
Ian
#101335 - 30/01/01 06:30 PM Re: Top Speed In 4H?
an1malch1n Offline
Loc: San Diego CA
You're right xoc I've done 80(Before I get yelled at it is a common thing when going through Wyoming on the flat Interstate, when there isn't any wind)Also once in 4hi and not going into reverse, at any point, you can shift from 2hi to 4hi at any speed. Which is why I was going so fast from dry to icy patches on the intersate. I only have a hardbody pickup(no X yet) but I'm sure nothing has really changed in the 4wd mechanism between the two.
[This message has been edited by an1malch1n (edited January 30, 2001).]
#101336 - 07/02/01 03:20 PM Re: Top Speed In 4H?
this is my first 4x4- I think I've figured out when to use hi and lo- sometimes when I go into 4h, I don't get it in all the way (apparently) because you can hear it spin like it's not catching. Then if I stop it will go in and stop the noise.
Do you smellalallalalala what Xrock is cookin?
