#100751 - 09/11/03 08:12 AM 4 Wheel Drive
I am new to the XTerra, is the 4x4 shift lever suppose to be in th N position when not in use or the 2wd High position?
#100752 - 09/11/03 08:35 AM Re: 4 Wheel Drive
2H is what you keep the truck in for normal use. go into 4H in snow, bad rain, when offroading, etc. N is for when you are being towed, need to push the car, and so on. If you are getting towed, you need to make sure that both sticks are in neutral. 4L is for when you're stuck in a ditch, etc, and only goes up to i think 30 mph.
#100753 - 09/11/03 11:26 AM Re: 4 Wheel Drive
Got an owner's manual?
Ugh, :rolleyes:
And if by chance you don't, download one .
#100754 - 09/11/03 01:34 PM Re: 4 Wheel Drive
Xtracurricular Offline
Loc: Denver, CO
also, you may still have the instructions right in front of you. Push your driver side visor down and look at the sticker on the ceiling behind it. Should be all you need.
#100755 - 09/11/03 06:34 PM Re: 4 Wheel Drive
ClaptoVaughn Offline
Loc: Southern California
wow...good thing you asked here first before experimenting on your own.
2hi for street use.
when offroad, shift to 4hi when under 25 mph. if going into 4lo, come to a complete stop during shifting in and out of 4lo.
and read your manual for good measure, buddy.
#100756 - 09/11/03 10:03 PM Re: 4 Wheel Drive
rrdstarr Offline
Loc: Tacoma
Never leave the transfer case lever in Neutral!!!
-Rick
#100757 - 16/11/03 04:38 PM Re: 4 Wheel Drive
OnlyOneDR Offline
...unless, of course, you are flat-towing your X...
http://www.noas4x4club.com/
#100758 - 16/11/03 06:47 PM Re: 4 Wheel Drive
DocNo Offline
Loc: NoVA
[b]Never leave the transfer case lever in Neutral!!!
...unless, of course, you are flat-towing your X...[/b]
??? No where does the manual ever state to leave the transfer case in Neutral. They state if you must tow with the rear or all wheels down, that it only works with the manual tranny in Netrual and the transfer case in 2HI with the autolocking hubs unlocked, and it also warns that you can't do it over 60MPH and if you are going long distance to disconnect the propeller shaft to avoid damage...
It's all in the owners manual that Brent linked to...
To be clear - NEVER leave the transfer case in Neutral. In fact the sticker behind the visor explicitly warns you to not leave the transfer case in Neutral.
Murderous Fire!
#100759 - 21/12/03 08:16 PM Re: 4 Wheel Drive
Buckshot Offline
Loc: Georgia
Who let you buy a 4x4 anyway???
Forgiveness doesn't come with a debt, but you my friend are now overdrawn!!
"Everybody to the limit, the Cheat is to the limit, everybody come on Fhqwhgads!"
#100760 - 21/12/03 10:48 PM Re: 4 Wheel Drive
RJ Offline
Loc: 100 Mile House, BC
This has been cleared before on a previous thread. N is useless on the X, which is different from some other manufactures (GM), who's N is designed for flat towing.
#100761 - 22/12/03 07:47 AM Re: 4 Wheel Drive
OnlyOneDR Offline
Well until the other day I did not realize that the Neutral position on the T-case kept the front and rear driveshafts locked together. I apologize for the stupidity displayed in my previous, above comment.
